ABS Problem after hard acceleration???
Old 7/29/07 | 07:24 PM
traffic142's Avatar
Question ABS Problem after hard acceleration???
I am getting a ABS trouble light both ABS light, Slippery road symbol and the traction control light comes on after hard accelleration. I have tried to already turn off the trac control, but the ABS still comes on?
Is it a sensor???
Is there a TSB on it???
Old 7/29/07 | 07:41 PM
theedge67's Avatar
Check your brake fluid level, it may be low. There is a sensor in the resevoir, if it is low that will trigger the sensor and show a light. Not sure if it will show the ABS light or the BRAKE light, but it is an easy check.
Old 7/29/07 | 08:08 PM
Mustang85's Avatar
What theedge67 said makes plenty of sense. This would especially be the case after hard acceleration - all the fluid would slosh to one side of the reservoir and might trick the car into thinking it is out of fluid!
Old 7/29/07 | 08:16 PM
traffic142's Avatar
check it ,not the problem
Old 7/29/07 | 09:10 PM
theedge67's Avatar
Anything more complicated than low fluid, I would take it to the dealer. They can diagnose the problem and fix it for you, probably under warranty, even though you have aftermarket rotors.
Gigantor
5/11/23 08:31 PM
RCooke08GT
2/19/17 04:03 AM
09-gt/cs
10/15/15 11:03 AM
boz
10/1/15 05:47 PM
