2006 GT Bucking manual after highway?
Old Aug 6, 2007 | 02:19 PM
KRASH1's Avatar
So this is strange, I have a 2006 GT with a manual 5-speed.
I totally baby this car, and I can't understand this wierd issue.
If I drive on the interstate for at least 30 minutes, then come a stop, and take off again, as soon as I take off in 1st gear my car will buck and practically stops me completely. Then as if the gears get aligned or something it continues on fine again, and drives/shifts like normal.
I hate to take this car into a dealer to have other people work on my car, but I may have no choice.
Any ideas?
Old Aug 6, 2007 | 02:58 PM
Sabre's Avatar
This sounds like the fuel pump problem that others have encountered after a long cruise. It seems that after and extended period of driving, air bubbles can gather around the fuel pump that is located inside the tank. When you stop and take off again, the air bubbles are taken in by the fuel pump and your engine is temporarily starved for fuel. Go back a page or 2 here in the warranty section and look for a post called " Getting the hesitation after long cruise TSB fixed".....there is technical service bulletin out on this very problem, which I think includes changing out the fuel pump for a new one.
Old Aug 6, 2007 | 05:02 PM
mitch e's Avatar
This TSB will fix you right up. mitch
Old Aug 6, 2007 | 09:06 PM
theedge67's Avatar
It is TSB 06-9-9. Find it, print it out, and take it to the dealer with you. Show them the TSB and tell them that your car is doing EXACTLY what the TSB describes. If they try and tell you they have to replicate the problem, that is BS, and don't let them try and put 30 miles on the car to *maybe* have the car do just like you said.
Old Aug 6, 2007 | 09:28 PM
stangster's Avatar
Yep - it's the TSB. Got mine fixed, no more problems.
Old Aug 7, 2007 | 11:03 AM
Donna's Avatar
Queen Of Nascar
TSB 06-9-9
I had mine fixed recently too. No problems since.
Old Dec 3, 2007 | 12:59 AM
fastduo's Avatar
Same here.
Old Dec 8, 2007 | 02:10 PM
Mach's Avatar
...and here...
Old Dec 8, 2007 | 02:21 PM
ShowGT's Avatar
Old Dec 18, 2007 | 07:34 AM
dustindu4's Avatar
9 is not my lucky number.
There is a gas pedal next to the brake pedal, push it when you let out the clutch
Old Dec 20, 2007 | 09:53 AM
withinavoid's Avatar
Good luck getting that TSB done. They will likely want to drive it and not even notice the problem. If they take your word you are lucky. Post your results.
NC14GT
Sep 10, 2017 04:47 PM
mx5jhb
Sep 30, 2015 04:44 PM
Kalel08
Sep 29, 2015 03:06 PM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
