2005-2007 vs 2008 4.6 3V Spark Plugs?
Old Feb 27, 2008 | 10:35 AM
  #61
05stangkc's Avatar
This Could be Handy Also!
Popular Products
6900Ford F-150 Spark Plug SocketWeight: 0 lbs.
• This unique and patented design works on 2004–newer Ford F-150 pickup trucks with 5.4L 3-valve Triton V-8 engines. • Socket end is 9/16". Soft rubber insert holds and protects spark plug during removal and installation. • Extension is part of the socket. Easily fits down spark plug tube in cylinder head. • Socket has 3/8" drive for use with a ratchet or breaker bar.
Both of these Tools are OTC Brand BTW!
Old Feb 27, 2008 | 11:11 AM
  #62
Rash's Avatar
What is Warrany in Service Date and What is your Mileage on Vehicle? I can Pull In Service from your Vin if you do not Know. If you do Not want to post you can Email me with Info and I may have a Helpful Answer. clevparts@aol.com
KC
Email sent - thanks KC.
Old Feb 27, 2008 | 11:17 AM
  #63
Rash's Avatar
Here's another one: http://www.amazon.com/SK-8-Inch-Driv.../dp/B0009WRL6A
Old Mar 2, 2008 | 06:01 PM
  #64
goldenpony's Avatar
Plugs
The only 1 piece design plug currently available for the 3V engine, to my knowledge, are the Brisk and the Champion #7989. The Brisk will be a fairly short lived plug because it has standard firing points. The Brisks are primarily for racing. The Champions should be long lived because they are copper core, double platinum, better for a daily driver. My next set will be Champions.
Old Mar 2, 2008 | 11:41 PM
  #65
302svt's Avatar
Great info KC.
Old Mar 3, 2008 | 11:18 AM
  #66
Centurion96's Avatar
From the photo in post #7 and the photo in post #28 it looks like Ford has changed their plug design. Are the '07+ plugs two piece or one piece and is there any history of these later plugs breaking? Looks like I'll have to pull my plugs next week to see what I have. I'll probably go the anti-seize route while they're out. My '07 has a build date of 12/04/2006 and has less than 8k miles on it.
BB
Semper Fi
Old Mar 3, 2008 | 03:07 PM
  #67
Rash's Avatar
BB
Semper Fi
Post #7 is not the factory plug.
Old Mar 18, 2008 | 07:30 PM
  #68
theedge67's Avatar
100K change interval. I was thinking about having mine changed soon, I even bought some new plugs in anticipation. Now I'm thinking I might wait it out, since I have 60K miles on them already. I'm thinking that I have a really good chance of the dealer breaking at least one plug, and they flat out told me that I would be paying labor on whatever they had to do to remove the broken plugs.
I'm having no issues with the plugs so far, everything is great...I might wait until 100K and then have them changed. At least then I can say I did exactly what was in the manual.
Old Mar 31, 2008 | 03:06 PM
  #69
seabiscuit's Avatar
Wow 280$ for Ford Rotunda / OTC 303-1203 Spark Plug Removal Tool.
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWD1V
Someone is getting nice business on that ford engine/spark plug mistake.
But what we want more that is only FORD = Fix Or Repair Daily
Old Apr 3, 2008 | 09:03 PM
  #70
randy_tho's Avatar
Apparently there is some news that they fixed this problem with a revised head cast and different plugs that thread to the end. It is on the board under the Installed Champions thread. I've posted on blue oval forums to see if an employee can verify.
I have an 08 so I guess I could go pull a plug and see. Apparently they started the revision late in 07 and for all 08s.
Old May 17, 2008 | 04:59 PM
  #71
blkstang06's Avatar
bump
Old May 17, 2008 | 11:15 PM
  #72
randy_tho's Avatar
Going by a newer TSB that describes another removal process, the heads were changed in 08 model year approx Oct of 07.
Old May 23, 2008 | 05:48 PM
  #73
infinityonhigh's Avatar
My car was built in November of 07 and when I pulled a plug it was still the old style. I was hoping I would have gotten lucky on this one. Although it would be better to check the engine build date instead of the car manufacture date as I have found the engine date to be October of 07. Guess I'll just have to replace them.
Old May 27, 2008 | 12:32 AM
  #74
coair73x's Avatar
Has anyone found out if the 08`s have the new design one piece plug? My 08 was built 4-21-08. Curious if there is a one piece design now.
Old May 27, 2008 | 06:13 AM
  #75
Cheese302's Avatar
i think i am going to change mine out just to be safe. i am guessing the brisk plugs are the best to go with?
Old May 28, 2008 | 02:41 PM
  #76
Your 08 should have them. Mine did not because it was an early 08.
Old Jul 15, 2008 | 06:09 PM
  #77
red454's Avatar
I have about 9,800 miles and I got a little nervous, so I decided to pull mine out, clean them and apply the anti-seize.
No problems; they all came out easily. One had some gummy carbon. The others were just dirty. But there was definitely carbon right at the seating chamfer on all of them. I used a small screwdriver to knock the carbon off. I applied the anti-seize on the first plug and installed it. I decided to see how much of the anti-seize squished out so I took the plug back out. It seemed to pick up a lot of crud from the spark plug bore, so I wiped it off and reapplied the anti-seize and did the final install. Did the same to the remaining plugs.
Started right up...
Old Jul 15, 2008 | 06:29 PM
  #78
70MACH1OWNER's Avatar
Started right up...
Any issues getting the COP's off of the spark plugs??? I have read it can be an issue.
Old Jul 15, 2008 | 07:35 PM
  #79
red454's Avatar
For the most part, they popped right off. A couple had to be wiggled a little. Be careful not to snag the fuel injector wires / plug when you pull up.
The engine was cold (ambient). The TSB originally said to warm it a little, but then they changed it to cold. They also say to loosen the plug 1/4 turn and spray some penetrating oil into the plug hole to soak for 15 minutes. I did on the first one, but realized that in my case it was not necessary.
duppycat
Feb 16, 2019 08:36 AM
Ray11
Sep 25, 2015 12:43 PM
Sep 23, 2015 03:21 PM
devildog1679
'10-14 Interior and Audio
Sep 14, 2015 02:17 PM
