07 mustang squeaks when side is shook
Old May 26, 2016 | 02:59 PM
rewardedgamer's Avatar
okay so i just bought this car and drove it 100 miles now this squeak has surfaced when driving around. so we were trying to listen to it and when my friend shook around in the passanger seat while the car was off you could hear a squeak on that side. anyone know what it could be? it seemed to get worse as i put another 200 miles on the car.
Old May 26, 2016 | 09:04 PM
houtex's Avatar
Easier way is to grab the fenders/quarterpanels at the wheel wells and pull up and shove down on the car, making it 'bounce', and that way you can hear the groans in the right areas.
You already know it's the right side, but how about front to back?
My guess is the bushings. Either the front control arm or the rear control arm. With a possibility of the strut or shock making groans. These are it typically is when these noises start up.
Might want to take it somewhere and put it up on a rack, have it looked at.
Good luck, hope that helps!
Old May 27, 2016 | 09:41 AM
il try doing that, i was sitting in the passanger seat and if i move a certain way i hear the squeak so im thinkin its the seat but im not exactly sure, idk how you could hear that from the outside though
Old May 27, 2016 | 09:46 AM
there are no groans just a little squeak normally shifting 1st/2nd/3rd but im pretty sure its not the transmission since the car makes the noise while turned off. also i dont hear the noise if im going like 60 and put it in neutral and cost to a stop going over bumps and such.
Old May 27, 2016 | 09:52 AM
i make the cars suspension compress a little couldn't really get it to move much but i didn't hear anything. but if i press the front right part of the seat you sit on it makes a squeaky noise. but like i said how would this be heard from outside and why would it make the noise when nobodys sitting in it?
Old May 30, 2016 | 11:31 PM
never mind its the lower control arms in the rear, i sprayed some lubricant on them and i think it went away būt i will see
SpectreH
Jul 31, 2016 11:26 PM
mark0006
May 25, 2016 11:45 AM
BlackGTCS
May 23, 2016 06:43 AM
SickShade14
May 4, 2016 12:30 AM
lsxjunkie
Apr 29, 2016 04:59 AM
