'07 GT/CS Battery Replacement Question
Old Feb 10, 2011 | 03:47 PM
pilatti1's Avatar
I have an '07 GT/CS with about 75K and i need a new battery any recommendations?
Old Feb 10, 2011 | 04:58 PM
Dougxox's Avatar
Not sure when you got your CS, but about the time I picked mine up there was a lot of warranty issues changing, mostly adding time and miles. You may be right at the limit, but check with the dealer and see if you can get it replace under warranty. Nothing like a free battery no matter what brand.
Old Feb 10, 2011 | 05:21 PM
2005GTDELUXE's Avatar
here is a recent thread
https://themustangsource.com/f669/tr...failed-476130/
Old Feb 17, 2011 | 08:19 AM
MusicMan66's Avatar
Standard warranty is 3 years / 36K miles, so it's out of warranty at this point. I just had mine replaced under warranty because it was struggling to start after sitting in the garage for nearly two weeks due to the snow we got (I did run it for 15-20 min. every couple of days, though).
The Optima and Interstate batteries are highly recommended.
Old Feb 17, 2011 | 10:08 AM
running it like you were probably didn't help the battery much. So is the warranty 3 yr 36 for everything and 5 yr 60k for the drive train??
Old Feb 17, 2011 | 10:09 AM
sears??
Old Feb 17, 2011 | 11:51 AM
05YellowGT's Avatar
+1 on the Sears ... I always use Sears when it's time to replace the OEM one , they have good batteries and a good warranty ...
Old Feb 18, 2011 | 07:29 AM
MusicMan66's Avatar
You're right. I knew it was on its last leg, so I just wanted to make sure I could get it to the dealership (although the warranty includes free towing ).
Yes. On mine at least, and I'm pretty sure the current warranty is the same.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
Jim74656
May 1, 2023 02:15 AM
defiance772
Oct 21, 2015 09:37 AM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
