Wheel bearings
Old Feb 15, 2011 | 10:52 AM
mustang6804's Avatar
Wheel bearings
I know I havnt posted in awhile but just wanted to give an update. Its time again to do wheel bearings on the cobra. Ive been doing research and it looks like I have to torque the spindle lock nuts to 225-290 ft/lbs of torque. Thats some crazy torque and Im just double checking that everything is correct with that. Thanks guys
Old Feb 16, 2011 | 10:20 AM
Mberglo's Avatar
That doesn't sound right to me. I'd keep researching. I believe you'd crush the bearing with that much force.
Old Feb 16, 2011 | 01:06 PM
HOSS429's Avatar
legacy Tms Member
i kind of thought so too but i have`nt worked on anything newer than 1980 ..maybe 225 to 295 inch lbs torque .. i dont think even a pinion nut goes 225 ft lbs ..
Old Feb 16, 2011 | 01:17 PM
I kept researching and found something that said 150. I got a 1" ratchet and just tightened it very snugly. I have test driven it and everything is good. Thanks for the input guys
Old Feb 16, 2011 | 02:53 PM
Mberglo's Avatar
When I've done spindle nuts, I tighten to seat the bearing and then back off until the wheel spins freely. Put the cotter pin in and go.
Your car may be completely different, but make sure the wheel spins freely or you'll really chew some stuff up in a hurry.
Old Feb 16, 2011 | 03:15 PM
That's how my 68 was mark. But I tightened the mess out of these and the hub was still spinning freely
JonathonK
Sep 24, 2015 06:31 PM
Steve@CJPP
Sep 15, 2015 06:20 AM
GMAYS
Sep 10, 2015 06:19 AM
