T-45 Bites the dust.
Old Nov 24, 2008 | 04:46 PM
workmangc's Avatar
Well, On Saturday evening I went for a little trip to do some bowling with some fellow European based Mustang owners. On the autobahn on the way back, doing about 110-120, 5th gear starts making a weird sound.....not good. I slow down and downshift to 4th, hoping that the 1:1 ratio will hold out and I nurse the car home doing about 45. Needless to say my 2 hour return trip took slightly longer. My post is immediately next to the autoban with only 1 stoplight in between. After stopping at the light and attempting to pull out I realize that 1-3 AND now 4th is making a sound. I can only guess that it is related to the input shaft since It doesn't make a sound with the clutch depressed but will make a sound even in neutral with the clutch engaged.Today I babied the car to the vehicle storage lot which is about 3 blocks from here and dropped it off for the deployment.
I have already decided on a T-56 swap. There are several vendors out there selling the 2003/04 T-56's. According to my research I will need to relocate my crossmember. I can reuse my brand new transmission mount with the 03/04 tranny's.
I will get a shortend drive shaft. I know that I could just shorten my stock one but I want to have all parts on hand and do the swap in 1 block of time. That and I would have to get a 27 spline yoke to re-use my stock one as well. By the time you add up the German labor rate and parts, I'm looking at a new one anyway. I will also have to wire up a reverse lockout switch but I understand that some don't even bother to do this anyway.
Other than that it seems like a straight-forward swap. I know I'll need a new shifter too, but I think that's pretty much it.
Anybody know if the tranny bolts are TTY?
Anything I'm overlooking?
Old Nov 25, 2008 | 06:52 AM
mustang6804's Avatar
Not sure if the clutch is the same for the T-56. 98 Cobra is a little different than an 03/04. Someone else might want to correct me but i believe the clutch system changed in 99 or 00
Old Nov 25, 2008 | 10:35 AM
workmangc's Avatar
The cobra's went to an 11" flywheel/clutch but it is still a 10 spline and the earlier clutch will work.
Mine has only about 8k miles on it so I'm sure it is fine.
Old Nov 25, 2008 | 01:45 PM
96TennGT's Avatar
Are you talking about Bell housing bolts? I reuse them. I don't think they are TTY. The 96 Service manual doesn't say anything about using new ones.
What are you going to do with the old T-45?
Old Jan 9, 2010 | 08:26 AM
workmangc's Avatar
Project complete.
see link for notes/problems/solutions.
http://www.mightymustangs.net/forums...quipped-cobra/
Last1
Sep 19, 2015 12:25 PM
aphaynes
Rocket City Mustang Club
Jul 9, 2015 09:25 AM
TampaBear67
Sep 25, 2004 09:26 AM
