new project direction
ok, well im finally done with school for now so i can spend a little more time on other projects now. 1 being a TT302 240z the other being a powder coating hobby i'll be picking up as soon as i get an oven.
but the is about the 302. ralph i'll need your help fairly often being it was your block, i lost all the info on it for some reason when i moved again, so if you could what is the rebuild kit i need to order and from where.
some of the things im lacking that i will be needing is a set of heads intake and ECU..i will slowly be gathering parts here an there. the main goal of this project is an old school junkyard hotrod style build. it is meant to surprise people on the street/ track.
let me know thoughts and ideas/ helpful information....i will be looking to you "older" ( its a relative term) more experienced guys to help me build the engine properly.
Any kit will do. I am not a fan of kits at the moment. I bought one, then still bought better gaskets. So, it ended up costing me more money than it should have.
You will be okay just buying name-brand stuff.
hehe, yep Twin turbo 302.
thanks ralph
Mberglo im not familiar enough with blow through carb setups to trust myself with it.
it'll be a while before i get the actually chasis, due to baby on the way, and im in the process of creating a greasel so i get free fuel....but im pouncing on any free parts that come may way by wondering on all the forums im on.
MAN im cheap!
thanks ralph
MAN im cheap!
Looking for a CHEAP/FREE houshold oven? Look around at some of the Thrift stores around town. They practicaly give that type of stuff away. Also, watch the curb, there's alot of 'flipping of houses' going on around here and perfectly good stuff gets thrown away. kennyg
really? thanks a lot kenny, im calling my wife right now!*
*disclaimer
not that it does much good to ask a pregnant woman to go look for something its the thought that counts...
*disclaimer
I thought that the hypers were more susceptible to damage due to detonation, not more pressure. Yet, I can see the thinking.
Regardless, I have heard people that just do not want to have them in their engine.
Yep, but since turbos are notorious for increasing heat and inherently compression (pressure), unless you have your timing and fuel supply correctly setup just right, detonation is very likely...
Sheesh, I thought a TT302 was for Time Trials. Seems like a huge project that would take a great deal of money and time to ever get on the road. I'd stick an OEM drivetrain in it and head to Steak n Shake.
always hatin', always discouraging people. Be sunny and optimistic, like me.
My thoughts, exactly. I'm thinking $20,000 for a correctly setup, tuned, reliable twin turbo 302.
