Installing new harmonic balancer?
Old Mar 22, 2007 | 04:24 AM
Mirage775's Avatar
OK, just so I don't screw this up, how exactly should I install my new balanacer I'm picking up today? This is what I'm figuring on doing, cleaning the original grease off the crank, rub down the crank some with emery cloth, regrease the crank and balancer and??? Should it just slide right on or what?
Old Mar 22, 2007 | 07:54 AM
Puter's Avatar
It may still need to "pulled" on. You can do this carefully with getting it started straight, then drawing it on with the bolt until it is seated. You will have to gauge this by the torque needed to turn the bolt. You definitely do NOT want to strip the crank threads. That would be a very bad day.
Once seated, I would back off, then torque the bolt to spec.
Old Mar 22, 2007 | 06:40 PM
Mirage775's Avatar
I got it fixed earlier, everything's working fine. Thanks
Old Mar 22, 2007 | 07:11 PM
65stangman's Avatar
Glad to hear it worked out fine. I would check it after a few drives and make sure everthing is staying in place.
Steve
Old Mar 23, 2007 | 04:13 AM
Mirage775's Avatar
Originally Posted by 65stangman
I would check it after a few drives and make sure everthing is staying in place. Steve
Yep, I plan too
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
Sep 8, 2015 10:45 AM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
