Broken Trans
Old May 19, 2008 | 09:47 AM
96TennGT's Avatar
Broken Trans
Hey guy,
Looks like I finally broke my T-45. Pops out of 1st really bad and does the same in 2nd sometimes. Does anyone have any experiance rebuilding one of these. I'd like to go T-56 but I just don't have the money for it right now. Any help is appreciated.
Byron
Old May 19, 2008 | 10:41 AM
NOStang05's Avatar
Hey dude,
Put a Viper 6 speed in it.
Old May 19, 2008 | 10:57 AM
LMan's Avatar
would that fit?
Old May 19, 2008 | 12:14 PM
Puter's Avatar
Hey Byron. As you know, I rebuilt my T5. Of course, since a bearing busted a few weeks ago, doesn't sound like I am the best to help.
They are both Tremecs. Can't be that much difference. Hanlon Motorsports http://www.hanlonmotorsports.com/ has three different types of rebuild kits. Problem is, you may have damaged first and second gears, plus the cluster gear shaft will need to be inspected well. Takes a few special tools and a press to rebuild them.
Old May 19, 2008 | 12:33 PM
Bigred15's Avatar
A Viper T56 will fit, it just takes some modification to the input shaft I believe. A T56 is a T56 no matter what vehicle it came out of. D & D Performance, I think thats the name, sells kits for the various T56 installs. If you have a mod motor you might look to install a Tremec 3650. They were installed on the 2001 Bullits and mid-01 and later new edge Mustang GTs. It is a much better transmission then the T-45 and T-5. Its just harder to come by. You would need a new shifter, but if you get a tranny from a junk yard you can probably use the one that came on it.
Old May 19, 2008 | 01:09 PM
96TennGT's Avatar
A T56 isn't the same for every vehicle. There are many different flavors. an 03-04 Cobra will slide right into place but has an electronic speed sensor instead of my mechanical (same goes for the 3650, it's just an update of the T45). A viper spec T56 has a 26spline input shaft and is rated to about 560ft-lb, Cobra is 440ft-lb I believe, it also has a different gear set that includes a .50 od 6th gear, again Cobra's have a .62 od 6th. Then there's the Corvettes and Aston-Marton which are both different than the others. As you can tell I'm researching options. The biggest problem with a T56 is price of entry; I would have to buy a driveshaft and crossmember also.
Ralf - Dad suggested taking it out and breaking it down and inspecting the damage. This may be my best bet at this point. If things are way broken then I can save the money on a rebuild and just get a new T45. Or just let the car sit for a few months while I save up for a T56.
FYI, there may be a few ways around the speed sensor issue but I'm not done investigating that yet. I know I can get T56's from D&D with mechanical speedo outputs.
Old May 19, 2008 | 01:11 PM
NOStang05's Avatar
Hey dude,
bullits had a 6 speed. your probably getting confused with the mach.
Old May 19, 2008 | 01:33 PM
Bigred15's Avatar
No Bullits did not have 6 speeds. There have been only two Mustangs that came from the factory with 6 speeds transmissions, the 03-04 Cobras and the 07-08 GT500s. Enjoy.
http://www.hotrod.com/featuredvehicl...itt/index.html
Old May 19, 2008 | 01:36 PM
NOStang05's Avatar
My friends Dads has a 6 speed. Maybe it was a option.
Old May 19, 2008 | 01:45 PM
Bigred15's Avatar
It was not an option either. If infact it had a 6 speed, it was not factory. There was a blue Mustang Bullitt floating around Huntsville about two years ago. I spoke with the guy about purchasing it. He had done a Viper T56 install, and several other mods including a Novi 2000. That may be the one you are thinking about. Trust me when I tell you that Bullitts were not available with 6 speeds in any way shape or form.
Old May 19, 2008 | 01:53 PM
Bigred15's Avatar
We now return to your regularly scheduled topic.
Old May 19, 2008 | 03:32 PM
96TennGT's Avatar
No 6 speed for the Bullit. No 6 speed for the new Bullit either.
Old May 19, 2008 | 06:20 PM
black_nightmare's Avatar
This wouldn't happen to be a true blue one with a Paxton supercharger would it?
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
