302 engine build
Old Sep 22, 2007 | 08:30 PM
usmcrebel's Avatar
302 engine build
OK i finallt got some pics from the 302 that i got from Ralph, i didnt get to do much, but its coming along.
Old Sep 22, 2007 | 08:34 PM
JedCranium's Avatar
What's your goal for your build? Tell us we want to know! What the history on the 302?
Bill2
Old Sep 22, 2007 | 08:49 PM
usmcrebel's Avatar
i really havent planned anything just yet, just clean it up for now, i was gonna put it in a miata, but i went and tried to get in one.......not happening im to tall. So now i am just cleaning it up.
Old Sep 22, 2007 | 09:11 PM
Puter's Avatar
I got it used ~8 years ago with ~25K miles. It was one of a set of engines a guy bought from Ford. It's a 93 block. I threw in a crank kit, new rings, FMS oil pump driveshaft, new lifters, left the cam in, 3-angled and ported the E7 heads, ripped the EFI and carb'ed it. Ran high 8's down at the track, but it was for my 84 daily driver.
In November, I was on a rally with one of the Vette clubs. I missed a shift, hit 8K, busted the oil pump driveshaft. Was in the hills of TN. Figured a wrecker would be expensive. Decided to drive it home 60 miles. The next weekend I replaced the driveshaft, pump, threw some oil in it and drive it until July when I swapped it out.
I am dying to see pics of the bearings.
Old Sep 22, 2007 | 09:21 PM
usmcrebel's Avatar
im gonna try to pull the pistons and everything this week, but no promises
Old Sep 24, 2007 | 09:09 AM
usmcrebel's Avatar
what does stroking a motor consist of and could i do it?
Old Sep 24, 2007 | 10:30 AM
HOSS429's Avatar
legacy Tms Member
swapping in a matched piston-crank and rod combo.. but unless you want to max out a high dollar small engine you`d be just as well off to pro-charge or supercharge your regular 302 cubes .. how much faster is a 347 small block than a 302 ..
Old Sep 24, 2007 | 10:36 AM
usmcrebel's Avatar
so with the 302 i got now all i need to do is swap the internals out, nothing else?.....if i had the money i would stroke it and blow it
Old Sep 24, 2007 | 11:42 AM
Faber's Avatar
now that is just dirty.
Old Sep 24, 2007 | 11:52 AM
usmcrebel's Avatar
i had to i couldnt resist
Old Sep 26, 2007 | 07:13 AM
LMan's Avatar
stroker kits are now reasonable, like ~ 800.00 for a basic rotating assembly. You need to notch the cylinder bores for a 347, but thats no big deal (can do with a Dremel).
JMO, if you are going to rebuild anyway, might as well put in a kit.
Old Sep 26, 2007 | 10:27 AM
Mberglo's Avatar
Opposing viewpoint...
331 gives you 10% more displacement. 347...about 15% more. This is the horsepower gains you should expect from the conversion.
I'd investigate the cost of a simple rebuild using same crank and rods.
Old Sep 26, 2007 | 12:30 PM
LMan's Avatar
suggest a comparison of torque, not HP, esp low-end torque...which is what you want in a street motor.
302 is short-stroke, which makes it particularly responsive to a stroking kit. but in any case, do your research, make your decision. Theres about 10000 metric tons of IntarWeb dedicated to Ford stroker tech, so surf and enjoy.
Old Sep 27, 2007 | 09:57 AM
usmcrebel's Avatar
what does that mean? just do a basic rebuild?
Old Sep 27, 2007 | 12:01 PM
Mberglo's Avatar
best case: bore cylinders, new rings, new pistons, new crank bearings, new cam bearings, check crank, check cam, check rods, reassemble.
Old Sep 27, 2007 | 12:07 PM
usmcrebel's Avatar
ok i got it...thats probably whats gonna happen
Old Sep 27, 2007 | 12:09 PM
usmcrebel's Avatar
how/ where would i get a bore from/done?
Old Sep 27, 2007 | 01:15 PM
Mberglo's Avatar
Best thing is to have an engine shop build a shortblock for you. You might call R&R speed shop, HSV Engine, Southern Cylinder Head, to list a few.
Of course, you'll also need a new oil pump, heads, gasket set, timing set, etc. Cheapest to buy this stuff from the machine shop as well.
Old Sep 27, 2007 | 02:06 PM
usmcrebel's Avatar
lol well, i can see where it helps to have funds that i dont, so i might just have to keep it "stock"
MustangGTCS13
Sep 17, 2015 07:38 AM
Evil_Capri
Sep 11, 2015 08:39 AM
dbent15
Sep 5, 2015 12:15 PM
