Spring and Summer 2012 Mods – 08 GT/CS
Got a few more things from my mod list completed:
Relocated battery to the trunk to make room for additional supercharger cooling capacity.
![Name: IMG_1665.jpg
Size: 90.6 KB](https://themustangsource.com/forums/attachments/f730/209214d1501539572-spring-summer-2012-mods-08-gt-cs-img_1665.jpg)
Added a Moroso Supercharger Coolant Tank
![Name: IMG_1690.jpg
Size: 121.3 KB](https://themustangsource.com/forums/attachments/f730/209215d1501539572-spring-summer-2012-mods-08-gt-cs-img_1690.jpg)
Added a Moroso Fuse Box Cover
![Name: IMG_1686.jpg
Size: 120.7 KB](https://themustangsource.com/forums/attachments/f730/209216d1501539572-spring-summer-2012-mods-08-gt-cs-img_1686.jpg)
Replaced my FRPP Strut Tower Brace with a BOSS 302 Brace (The BOSS Brace provides clearance for a FRPP 3V Intake)
![Name: IMG_1692.jpg
Size: 109.7 KB](https://themustangsource.com/forums/attachments/f730/209217d1501539572-spring-summer-2012-mods-08-gt-cs-img_1692.jpg)
FRPP Intake ready to install
![Name: IMG_1537.jpg
Size: 99.6 KB](https://themustangsource.com/forums/attachments/f730/209218d1501539572-spring-summer-2012-mods-08-gt-cs-img_1537.jpg)
However, I ran into a problem as illustrated in the next two pictures. As part of the Vortech Supercharger install Vortech provides a ½” spacer that goes under the thermostat housing to allow clocking the thermostat housing a few degrees clockwise for supercharge clearance around the radiator hose. This extra ½’ of height on the thermostat housing prevents the intake from seating. First pictures shows the intake sitting on the thermostat housing and the second picture shows the spacer and the gap between the intake and the head.
![Name: IMG_1579.jpg
Size: 92.6 KB](https://themustangsource.com/forums/attachments/f730/209219d1501539572-spring-summer-2012-mods-08-gt-cs-img_1579.jpg)
![Name: IMG_1584.jpg
Size: 79.0 KB](https://themustangsource.com/forums/attachments/f730/209220d1501539572-spring-summer-2012-mods-08-gt-cs-img_1584.jpg)
Back to the drawing board on this mod. I need to fashion a solution that eliminates the Vortech spacer and permits clocking the thermostat housing.
Installed a FRPP GT500 leather Wrapped Steering Wheel
![Name: IMG_1635.jpg
Size: 86.7 KB](https://themustangsource.com/forums/attachments/f730/209221d1501539572-spring-summer-2012-mods-08-gt-cs-img_1635.jpg)
And lastly added a Center Fog Light Honeycomb Grille by Street Scene
![Name: IMG_1699.jpg
Size: 133.4 KB](https://themustangsource.com/forums/attachments/f730/209222d1501539572-spring-summer-2012-mods-08-gt-cs-img_1699.jpg)
Steering wheel install is pretty straight forward, about 30 minutes while taking a few pictures. In the mess I call a garage it likely took me longer to find all the tools than do the job. lol
You need a small flat blade screw driver, 8mm deep socket, 24mm socket, ratchet and torque wrench and that is about it.
Basically:
1. Disconnect battery.
2. Remove plastic caps (2) with a flat blade screw driver and then 8mm bolts (2) (one each on either side) of the wheel/column.
3. Pull the center of the steering wheel out (CAREFULL airbag)
4. Disconnect air bag connections (2).
5. Remove the center bolt with 24mm socket.
6. Carefully pull the wheel off (no puller required) and using your flat blade screw driver disconnect the harness from the plug.
7. Repeat the steps in the reverse order (torque the 24mm bolt to 41 lb/ft) and you are done.
Part number is AR3Z-16A200-A it is the brace for a 2012 Boss 302 and also the base Mustang. Fits just fine on my 08. I needed this brace because it is higher than the FRPP Brace and it will clear a FRPP 3V Intake. I do have an aftermarket hood, wonder if that is why it fits?
“Ride” quality is clearly an aspect of personal choice. In addition to the GT/CS I have a 1970 BOSS 302 (now in a very slow restoration). My wife would describe the BOSS as “noisy, bumpy and stinky”; she describes the GT/CS as “noisy and bumpy”. While I think both cars are neither noisy nor bumpy, the BOSS was definitely stinky. I would describe the ride in the GT/CS as nothing but “fun”!
I will be shortly completing a forged engine build and after the new motor is in I am sure I will be able to describe the ride as “even more fun”. Lol
![Name: IMG_3686_zpsc278dc50.jpg
Size: 137.4 KB](https://themustangsource.com/forums/attachments/f730/199326d1501304256-spring-summer-2012-mods-08-gt-cs-img_3686_zpsc278dc50.jpg)
![Name: IMG_3607_zpsa65fde01.jpg
Size: 134.1 KB](https://themustangsource.com/forums/attachments/f730/199327d1501304256-spring-summer-2012-mods-08-gt-cs-img_3607_zpsa65fde01.jpg)
![Name: IMG_4064_zps0cba8667.jpg
Size: 122.2 KB](https://themustangsource.com/forums/attachments/f730/199328d1501304256-spring-summer-2012-mods-08-gt-cs-img_4064_zps0cba8667.jpg)
M3hunter
9/10/15 09:26 AM
