Speaker Vibration?
May sound funny... My left door base speaker was making a small rattling noise / vibration.....took it in to dealer.... Wife had put a couple of ball point pins in the door "pocket" / storage area....hence the rattle.....
Probably not your problem, but check those storage pockets ----- lest you feel/look like a "#$%@#" at the dealer......Actually, I had them check it during a routine oil/filter change.... Oh yeah, after removing the couple of pens in there --- Shaker 500 has been fine.
If anybody on this forum needs info on a TSB for their vehicle, just let me know. I work for Ford and have access to their protechnician intranet site.. The speaker vibration was definately a problem - The dealers were replacing a lot of speakers in the beginning thinking they had been blown. Problem turns out to be the wiring in the door -
Now if I could just figure out why my right A/C vent is rattling....can't blame it on a pen in there...
Resurrecting old thread
Got this from a guy over at s197forum:
Tsb 07-17-06 Buzz/rattle
FORD:
2005-2008 Mustang
ISSUE:
Some 2005-2008 Mustang vehicles built before 8/2/2007 may experience a buzz/rattle from the door panels when using the radio/CD player at elevated volumes or bass levels or voice broadcasts. This may be due to the window switch bezel vibrating against the door trim panel. This can often be incorrectly diagnosed as an audio speaker buzz or a bad speaker.
ACTION:
Follow the Service Procedure steps to correct the condition by applying foam tape to the window switch bezel.
SERVICE PROCEDURE
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
FORD:
2005-2008 Mustang
ISSUE:
ACTION:
SERVICE PROCEDURE
- Remove window switch bezel from door panel and separate the two piece bezel.
- Install three (3) pieces of PVC soft foam tape 3/8" wide by 1 3/4" long (10 mm by 45 mm) part number 164-R4901 from the Rotunda Squeak and Rattle Repair Kit part number 164-R4900.
- Reinstall window switch bezel and verify proper operation of the window switches.
Thanks for for sharing this. I just inherited my dad's 2006 GT and this was driving me nuts, mostly on the driver's side. I tossed some foam under the window control trim and was good to go, thanks to finding this thread.
