A small request
A small request
Could one of you CS owners out there take a pic of your car with the following stipulations.
1.Direct level side shot(side stripe is the center focal point)
2.get as close to the stripe as you can with out cutting off any of the side of the car (up to the edge of the door that is)
3. if your car is black or vista try and get it so the stripe is as visible as possible.
I need this shot for balancing/alignment to make sure the ones I put on can be leveled properly.
Thanks in advance for helping me out here.
Thanks to both of you. Ed if you don't mind could you take a shot of the side of the car getting as close as you can while showing the entire stripe. I need mine to be level like on the CS and some pics would help. Again thanks!
Super Moderator
TMS Staff
TMS Staff
Are you adding Gt/CS stripes to a GT to make a clone? Or have you had to replace the stripes on a GT/CS?
Curious since the factory stripe kit has alignment marks on the decal backing sheet.
TDS
No not doing a clone. Just really like fading side stripes and I already have a design, I just need them to be aligned properly and since my stipes came from a shop I don't have the luxury of said backing sheet, thanks for the info though. Currently the stripes on mine slope down and I never noticed until I compared it to a CS so I just need some direct side shots so I can see which body line they use to make them straight.
Tom,
The stripe is 5 3/8 '' below the door body line which is directly under the outsdie mirror,
hope these pics help, provided I can get them loaded.
The EDGE ( clear part ) of the stripe is 5 3/8 on the passenger side and 5 1/2 on drivers side.
Ron
Ron
