Rear Window Panel Removal
Old Jan 5, 2007 | 11:51 AM
NJJOE's Avatar
I am going to change the rear speakers out and there are no speaker grills on the 2007's. The panel on the needs to be removed. I heard that the side panels just pop off. Is there a trick or tip to do this, I tried and they wouldn't just pop off. Maybe I was not trying hard enough, just didn't want to force it. Tips...Suggestions?
Old Jan 5, 2007 | 01:32 PM
f1-cobra's Avatar
You need to start with the entry guards, they are held on with clips and tape. Then remove the rear seats and on to the rear side panels. You need to remove 3 of those christmas tree clips on each side and pull the panels off. Then the parcel shelf has 4 of those tree clips, 2 on each side and it slides out.
The hardest part is getting those clips out. Also, putting it back together, take your time with the side panels. It took me a while getting it lined back up correctly. It also helps if you can find the service manual pages on these panels.
Old Jan 5, 2007 | 03:31 PM
f1-cobra's Avatar
Now that I'm home I will post the instructions from the service manual.
1. Remove the door scuff plate.
2. Remove the quarter trim panel lower pin-type retainer.
3. Fold the rear seat forward, remove the 2 pin-type retainters and rear quarter trim panel.
4. Remove the 4 parcel shelf pin-type retainers.
5. Position the 2 rear seat belts aside and remove the parcel shelf.
6. To install, reverse the removal procedure.
They don't go into very much detail.
Old Jan 5, 2007 | 03:33 PM
f1-cobra's Avatar
Here is the exploded view of the interior trim.
File Type: pdf
Old Jan 5, 2007 | 03:57 PM
NJJOE's Avatar
Thanks. That sure helps a lot. Now I just have to find the time. I appreciate your help.
Ecostang
Nov 3, 2022 08:50 PM
Aug 25, 2015 07:15 AM
Last1
'10-14 Exterior Modifications
Aug 13, 2015 01:16 PM
lakersfreak
Aug 12, 2015 01:52 PM
stewarts359
Jul 31, 2015 08:46 PM
