Need some help,gt grill
Old Jan 29, 2010 | 03:19 PM
srfulton's Avatar
What screws are used to attache the fog lights to the gt grill? I bought them separate and the grill does not have the screws. thank you
Old Jan 29, 2010 | 05:42 PM
ford4v429's Avatar
legacy Tms Member
just happened to have a spare grille sitting downstairs- didnt have a torx wrench handy, but anyway...as you can see they have a integral flange/washer- might be best to stop and pick up a few from the dealer...
Old Jan 30, 2010 | 07:00 PM
srfulton's Avatar
thank you for the help
Old Feb 7, 2010 | 09:06 PM
ksguy73's Avatar
A couple of them are a little shorter than the others too so be careful. I can't remember for sure which ones were shorter but I remember this being warned in the directions that came with my eleanor grill I put on my '08.
Old Feb 8, 2010 | 05:40 PM
ford4v429's Avatar
legacy Tms Member
ok...sorry I didnt check the other day.
T25 torx, integral 11.75 mm washer, 16mm long, 6mm major thread diameter, 3mm pitch, self tapping...on my 'newtakeoff' GT grill all 4 are the same length- measured the depth (thru the light plus depth of hole in grille) max length on the outer would be about 16.5mm, inner are 17 and 19, near as I can measure...
still looks like a special to me, still think dealer would be best bet...if you want to try tapping/using something else, the minor on the screws looks to be around 3.3mm, and theres a short shoulder thats a even 4mm
this is by far the most Ive ever written about a self tapping screw- hope it helps
edit- they are either a magnetic stainless(doubtful) or zinc/similar plated
Old Feb 8, 2010 | 05:42 PM
Whosit's Avatar
Can you be more specific please?
Old Feb 8, 2010 | 05:45 PM
ford4v429's Avatar
legacy Tms Member
ok, I edited a little
Old Feb 13, 2010 | 10:39 AM
srfulton's Avatar
Thank you all for the help.
May 3, 2026 05:42 AM
Cobiecane
Oct 23, 2015 08:44 AM
mlcinema
Oct 7, 2015 10:05 AM
