MY NEXT MOD -Shelby CS8 grill.
1 Post
this is going to be my next mod ,,
I will have to get another stock GT grill thoe to do all the cutting ,you have to have a ( stock 2005-09 GT mustang grill ) to do the mod ,alot of cutting on the stock grill as a backing plate,,you can get the grill parts for about $ 160.00 at Shelby parts ,and the grill with the PIAA lights kit for about $ 440.00 everything but the stock GT grill,,,just another winter job to do,,I'm going to save the stock GT grill the one that came on my car,,I will post more pictures later when I'm done with the mod,,,,what do you think about the grill change,,+ or -,,
Good luck and great choice! I have been considering that one as well and picked up a donor grill a while back for $35. I heard the modification process with the stocker is fairly time consuming along with the CS grill not not coming with very good instructions. Post some updates on how it goes.
1 Post
this is going to be my next mod ,,Attachment 71583
Attachment 71584 I will have to get another stock GT grill thoe to do all the cutting ,you have to have a ( stock 2005-09 GT mustang grill ) to do the mod ,alot of cutting on the stock grill as a backing plate,,you can get the grill parts for about $ 160.00 at Shelby parts ,and the grill with the PIAA lights kit for about $ 440.00 everything but the stock GT grill,,,just another winter job to do,,I'm going to save the stock GT grill the one that came on my car,,I will post more pictures later when I'm done with the mod,,,,what do you think about the grill change,,+ or -,,
I like that grill too! I looked at it a few months back. Didn't realize you need a stock grill and that so much work was involved. Guess I'll just keep what I got. Post up some pics of the install when you have time.
1 Post
got a update today,05/08/2010,they said now I should get the right grille this Wednesday,05/12/2010,,I sure hope so,,so far I got about $ 400.00 dollars into this grille mod,,I will take some pictures as I get started doing this ,the cutting of a stock GT mustang grille .
1 Post
got a update today,05/08/2010,they said now I should get the right grille this Wednesday,05/12/2010,,I sure hope so,,so far I got about $ 400.00 dollars into this grille mod,,I will take some pictures as I get started doing this ,the cutting of a stock GT mustang grille .Attachment 75229
1 Post
1 Post
O-buy the way,in case some of you don't know the Shelby CS6 / CS8 grille is all metal,,not plastic,,and Shelby makes a grille frame so you do not have to cut up a stock Mustang GT grille ,price for that one is $ 104.00 ,you can see it at the ShelbyStore.com,,but being a member as I am ,I'll be able to save 10% off all orders ,,,
According to Shelby you still have to modify your grill, which is not the end of the world but you think they would have just designed it better from the begining.
Shelby factory original on the 2005-2009 Shelby CS8 models>
Notes:
• Requires modification of a 2005-2009 Ford Mustang GT grille to install.
• Fits stock Mustang GT front fascia.
• Grille has provisions for driving lights, but are not provided.
• "Shelby" lettering and letter backing plate not included.
Notice:
This grille is a service replacement part for existing CS owners. Effective 03 May 210, CS grilles will no longer utilize center driving lamps.
1 Post
1 Post
,,,,I was told by the people at Shelby Parts,that it is the one ( they came up with / had made ,just to make it easy for them to do their mods at their shops ), / faster than using a stock GT grille as a backing,,it is the same grille and housung used on the Terlingua Mustangs,,the mounting holes for the CS grille are already there,,just slide it into place and bolt down ,you can go the the ShelbyStore.com and see it up close,,I will post some pictures when I get all the parts together,,before and after install ,since there will be no cutting on the stock grille ,should be quite easy,,just remove the stock grille housing with the factory fogs,,and put together the CS grille and install back,,,I will try and take as many pictures as I can ,,so this mod will be more easy for someone else thinking about doing the same,,I see the only problem that may come up is the mounting of the PIAA light mounts ,but I already have quite a few pictures from my friends over at TeamShelby that will help,,thanks for posting and looking in ,,Respectfully Richard
1 Post
