Has anyone lowered there’s I’m thinking about the ford performance lowering-k spring
There are a million choices for lowering, the FRPP K springs are a pretty good choice if you want to lower 1.5", which is a bit on the aggressive side IMHO
things to think about for lowering:
how low do you want to go -- what are the roads like in your area? generally 1" is pretty safe, 1.5" is getting a bit aggressive, more than that is quite aggressive
do you want stiffer suspension or just lower? most lowering springs are stiffer than stock, but there are some that are similar to stock
stiffer springs need more damping to go with them, so you generally want new struts/shocks to go with them
lowering does cause some geometry issues, such as increased negative camber, rear axle will move off center . . . you can ignore these issues or correct them with more new parts
try some searches on the main 2005-2009 forum and you'll find lots of threads on lowering; and if you have specific questions not answered by those other threads you can post a new thread for those questions
Nice car. I used Steeda sport springs on my 08. They give a nice drop. I would like to be a little lower but I have enough issues already with speed bumps and angled driveways.
