Differnte size tires on OEM rims
Old Aug 22, 2011 | 11:47 AM
gstottsjr's Avatar
Has anyone used a different size, from the OEM, tire on the GT/CS 18" rims? Has anyone had any bad experiences with the BF Goddrich G/Force tires?
Old Aug 22, 2011 | 02:55 PM
frank s's Avatar
A quick search will reveal dozens of threads about tire-size and B F Goodrich tires.
Consensus seems to be that you don't want to go larger than 255-series with the 18x8.5 rims.
During the approximately 8,000 miles I drove on two different sets of the BFGs I found them to be good all-around tires, comfortable and pretty sticky, without much noise or tramlining.
Old Aug 25, 2011 | 09:12 PM
G Wrecks's Avatar
I've got 275/40/18's on my stock wheels (rear) with no problem. I've got 245/45/18's up front.
Old Aug 25, 2011 | 09:44 PM
mustangGT90210's Avatar
I will buy Jack Stands!!!
It's absolutely amazing the difference in the truck world and mustang world as far as tire sizes go. I have 7.5 inch wide rims and a 265(10.5) inch tires with no issues.
What is the reason for the differences here?
Old Aug 25, 2011 | 09:59 PM
What series tire is it? 70 series? 75? The taller sidewall allows for the tire to balloon out more.
Old Aug 25, 2011 | 10:11 PM
31x10.50 comes out to officially a 265/75
Old Aug 25, 2011 | 10:17 PM
Ok so the sidewall height is determined by the 265/75. 265mm is the width of the tire tread and the sidewall height is determined by multiplying 265mm x 75%. Which is roughly what? 198.75 mm or a little under 8".
So a tire with an 8" sidewall can fit on a 7" wide wheel with a 10.5" tread width q heck of a lot easier than a tire with a 3" sidewall.
Old Aug 28, 2011 | 03:33 PM
Ok I understand that now, thanks Gary
14BlackGT
Aug 26, 2015 12:33 PM
Jul 20, 2015 06:26 AM
