Dealer had to replace 2 retaining clips for the belly tray in the front fasia
Two of the retaining clips for the undertray of the front fasia had to be replaced they kept coming loose. Just an FYI for all GT/CS to check the undertray of your fasia.
Just checked mine and the outside one on the driver side has already popped out and won't really stay put when put back in. Rather than have the dealer put the same POS piece back on, I'm going to go and pick up a small bolt, washers, and locknut and swap out all three.
I ended up swapping out the two outside clips for small stainless bolts and washers with locknuts. However, the center nut is near impossible to reach so I left the stock junk in place. It hadn't come loose yet and hopefully with the two new outside bolts in place it won't. I also noticed the rear bumper fascia lower fasteners are very flimsy. I am hoping that they will stay put.
