ARP Long Rear Wheel Stud Install
Old 2/6/12 | 11:46 AM
Scott2's Avatar
Before OEM Studs:
INA bearing, flat washer and lug nut used to pull the ARP studs into place:
Comparison between the OEM and ARP studs with McGard open ended lug nut:
Open ended McGard lug nut showing removable plastic cap:
After ARP rear studs installed:
Old 12/10/14 | 11:09 AM
ticopowell's Avatar
Are the studs press fit in? did you have to pull the axle out to put them in?
Old 12/10/14 | 11:40 AM
Scott2's Avatar
Axles still in the car, the old studs were banged out one at a time with an old wheel nut threaded on them. New studs were installed with a small bearing, washer and wheel nut. See the second picture in my install post. The bearing is the key makes pulling the new stud through a piece of cake.
RocStar69
8/21/15 07:33 AM
Quick Reply: ARP Long Rear Wheel Stud Install
