ARP Long Rear Wheel Stud Install
Before OEM Studs:
http://i955.photobucket.com/albums/a.../IMG_0386a.jpg INA bearing, flat washer and lug nut used to pull the ARP studs into place: http://i955.photobucket.com/albums/a.../IMG_0511a.jpg Comparison between the OEM and ARP studs with McGard open ended lug nut: http://i955.photobucket.com/albums/a.../IMG_0541a.jpg Open ended McGard lug nut showing removable plastic cap: http://i955.photobucket.com/albums/a.../IMG_0553a.jpg After ARP rear studs installed: http://i955.photobucket.com/albums/a.../IMG_0505a.jpg |
Are the studs press fit in? did you have to pull the axle out to put them in?
Thanks |
Originally Posted by ticopowell
(Post 6877004)
Thanks |
