3.55 axle ratio help??
Old Apr 6, 2007 | 09:27 PM
BaknBlak's Avatar
Is this optional for automatics and standard for manual??.....or is it optional for manual as well??....I'm still waiting for a vin# for my gt/cs....but for some reason, i assumed the gt/cs came with the 3.55's but browsing through the 2007 order guide, i don't see the 3.55's standard on anything!!...So i just want to confirm, what gears did you get with your cali special,3.55's or 3.31's....and if 3.55's, did you ask for them?
Thanx
Old Apr 6, 2007 | 09:32 PM
VegasGold's Avatar
I assume the Mustang comes standard with 3.31 in 2007. You need to ask for the 3.55 option...I understand it is $100 more...
Check with your dealer...You can still add them if you are not serialized...
Old Apr 6, 2007 | 09:36 PM
karman's Avatar
Thanx
All the Mustangs now come with 3.31.
The 3.55 is an option for the manuals.
Order code 455 is the 3.55 axle.
You need to have order code 455 to get the 3.55 gears no matter what.
Old Apr 6, 2007 | 09:40 PM
BaknBlak's Avatar
Thanks for the quick reply joseph, gonna call my dealer tomorrow. I want those 3.55's....thanks again.
Old Apr 6, 2007 | 09:43 PM
BaknBlak's Avatar
Order code 455 for 3.55's, cool....thanks karmen.
Old Apr 7, 2007 | 06:36 AM
SteelTownStang's Avatar
+1... Definitely worth the $100.00 bucks
Old Apr 7, 2007 | 09:42 PM
mvon919's Avatar
get the 3.55 ring/pinion later. that 3.55 axle weighs a ton.
Old Apr 7, 2007 | 10:45 PM
theedge67's Avatar
What?!? It's the same axle, just different gears in the rear end. Same weight. Where did you get this from?
Old Apr 7, 2007 | 10:46 PM
karman's Avatar
EXPLAIN PLEASE !!!
Old Apr 7, 2007 | 10:48 PM
jacostang's Avatar
Yeah! I don't get that one???????? Splain!!!
Old Apr 7, 2007 | 10:52 PM
SlamMan02's Avatar
Old Apr 8, 2007 | 09:54 AM
BaknBlak's Avatar
Hey guys, I didn't know it but when i went by my dealer yesterday, i found that the U.S. and Canadian order guides are alittle different....The Canadian guide shows 3.55's standard on GT Manual Trannys only and 3.31's for everything else....We even tried to add the order code (455) to my order and nothing came up in the system....That seems to be the only differance between U.S. and Canadian guides.
Old Apr 8, 2007 | 08:18 PM
karman's Avatar
The Canadian build and price does not list the option.
Now we know it's an EPA thing.
Old Apr 8, 2007 | 08:45 PM
BaknBlak's Avatar
Yeah, if you click on view standard equipment on the right side of the page just above selected equipment, it'll have the 3.55's on the list....Lucky us,huh??.....lol
P.s....Whats an EPA thing?
Old Apr 9, 2007 | 08:18 AM
HOTLAP's Avatar
Thanx
If you ordered from a Canadian Ford dealer - I believe it's still standard on the manual.....
Old Apr 9, 2007 | 10:11 AM
tuco's Avatar
Yep, that is true.
Rando
Aug 25, 2021 11:12 AM
Rando
Sep 30, 2015 12:28 PM
Sep 24, 2015 08:15 PM
Sep 10, 2015 12:44 PM
earl610
Sep 6, 2015 05:48 PM
