Are there any throttle body swaps for the GT500 yet?
Are there any TB swaps for our GT500s?
I saw a 75mm KB throttle body but I don't think it is a swapable unit. I "think" they only make or support it for their blower swaps. They report a 48rwhp gain over the stock TB but I can't find details on whether that is on the stock blower or the KB blower at the stage 1 level...
I can only guess at this point but that TB with their CAI, some axle backs, and a good tune would result in something around 520rwhp??? Purely a guess on my part... Assuming others reporting 510rwhp without a TB swap and KB states that the stock TB is restrictive as low as 435rwhp...
What do you folks think?
I had a V-10 Ford Truck on for a while with my whipple but have changed to whipples single blade- still have the V-10 It was good for 20 RWHP on mine its just a little bigger than stock. You can try B4 u buy if interested!!!
I have been following a KB 2.8 stage III up-grade on another board for the GT500. They are saying that the KB 75 mm throttle body and intake track gives 4lb of boost 18.5 to 23+. This is with no pulley change just the throttle body. On a stock blower I am not sure if it will give you that much of a HP increase. On a side note this is where the GT500 start to show what it's made of. Almost 700rwhp with just a blower swap. Still using the stock fuel system "pumps, rails and injectors". The only thing being changed out is the drive shaft and tires. Also I am not reading about blown motors or trans with this car. It may be a pig but but feed it more air and fuel and it's a fast pig.
And, I don't want to purchase a "kit" with a CAI/tune until I know about the various available TBs and what CAI they use and if they require a specific set of drivers for the tune...
If you are going to use the stock blower then the stock TB will be fine.
Do a pullt CAI Exhaust and tune and it will really wake it up. My only experiance with dlowers is with Whipple as thats what I have.
