New Stillen 2-Piece GT500 Rotors!
Old Sep 15, 2008 | 09:58 AM
Derek@DRI's Avatar
You guys asked for it, and STILLEN responded!!
The Front 2-Piece Rotors are now available in both Slotted, and Cross-Drilled/Slotted versions.
These direct replacement two piece rotors are a race proven performance upgrade that deliver improved stopping and fade resistance over the factory rotors.
The two piece design reduces unsprung weight and heat transfer into the bell area reducing the possibility of warping. The Pillar vane disc design reduces weight and adds 20% greater cooling, while making the disc stronger with improved stability. Friction surfaces come in two configurations, cross-drilled/slot or slot only for rapid removal of friction gases and anti-glazing.
Each disc is heat treated for thermal stability and has thermo-graphic paint marking for temperature monitoring.
Click on the links or give us a call to order.
http://dagostinoracing.com/index.php...ducts_id=15943
http://dagostinoracing.com/index.php...ducts_id=15942
GLOCKer
Sep 28, 2015 05:20 PM
UOP Shadow
Sep 27, 2015 07:24 AM
Sep 16, 2015 06:44 PM
