'07 GT500 Traction Issues.
Old Dec 13, 2013 | 07:02 PM
VenomousCobra's Avatar
I have an '07 GT500 that I installed a JLT CAI, with a custom tune and Borla cat back exhaust on, and naturally I can't keep the stock tires planted. I'm upgrading to MT drag radials soon, my question is what suspension components would help with traction right off the bat? I plan on buying some lower control arms to get the wheel hop under control. What else will help?
Not so concerned with cornering, mostly straight-line traction.
Old Dec 14, 2013 | 07:20 PM
I would find the best tires I could first. Nice wide summer tire. I would also upgrade uca/lca panhard bar... See how it feels after that. Maybe some adjustable shocks and struts after that.
Old Dec 14, 2013 | 07:32 PM
That's what I was thinking too. Thanks for the help.
Old Dec 15, 2013 | 09:07 PM
bob's Avatar
bob
LCAs with relocators did a good job on my car when it was relatively stock.
Also how often do you drive your car? I used a set of NT05R Drag radials for about 6,000 miles. A drag radial isn't a tire I would recommend for anything other than limited street driving in warm dry weather and even then they are only really useful for their intended purpose.
Combined with the stock type high performance front tires they create schizophrenic handling in the car under duress.
Old Dec 15, 2013 | 09:31 PM
Originally Posted by bob
LCAs with relocators did a good job on my car when it was relatively stock. Also how often do you drive your car? I used a set of NT05R Drag radials for about 6,000 miles. A drag radial isn't a tire I would recommend for anything other than limited street driving in warm dry weather and even then they are only really useful for their intended purpose. Combined with the stock type high performance front tires they create schizophrenic handling in the car under duress.
I drive it regularly during the summer months. The drag radials would be for track days, although any street tires you recommend that perform better than the goodyears?
Old Dec 16, 2013 | 06:56 AM
bob's Avatar
bob
You have a wide selection of tires for the front, the rears not so much
I'm running Nitto NT555s right now and I find them to be about the same as the OE Goodyear's which IIRC Ford selected due to their wet performance.
The Nitro Invo would be the up fit in their line of performance tires, unfortunately I have no experience with them.
Getting a higher quality summer tire like a Michelin requires going to a larger diameter rim unless an all-season tire is an option as Michelin's Pilot A/S 3 is available in the stock size.
The A/S 3 might not sound like a good choice but Michelin is claiming they out perform Conti's Extreme Contact line and Pirelli"s P Zero Nero line in dry handling.
Bridgestone has a summer tire but its a run flat, it's a valid figment because you have TPMS but the tires are heavier and stiffer all of which will degrade the ride on your car and possibly the handling.
Old Dec 16, 2013 | 07:22 AM
The Michelin® Pilot® Sport Cup summer-only tires deliver powerful performance cornering, race-like reflexes, and consistent performance lap after lap. It’s everything Michelin has learned through its extensive Motorsports experience combined in one tire to achieve 1.13g skid pad and 8% more grip than standard PS2 tires, which amounts to 3 seconds saved per lap at Virginia International Raceway. Available with the PDE Package.
good enough for the Zr1 vette. You can also click on tires in my sig for an old tire test shootout
Old Dec 16, 2013 | 08:48 PM
bob's Avatar
bob
One of these days I get around to running 19" rims on my car and go for a set of Pilot Sport Super Sports.
GLOCKer
Sep 28, 2015 05:20 PM
UOP Shadow
Sep 27, 2015 07:24 AM
Sep 8, 2015 10:45 AM
JTB
Motorsports
Sep 3, 2015 10:50 AM
