Wind Noise '12
Wind Noise '12
Took my '12 Mustang on the interstate and noticed a lot of wind noise coming from the passenger side window area. Have been trying to figure out where it's coming from but no luck so far. Noise starts at around 70 to 80 mph
I tried asking someone to point a hairdryer around the window while I sat inside but I think it's too weak. Also tried putting tape over certain areas like where the side mirror connects to the car but no luck yet. Any of you guys experiencing the same thing? Any ideas on how I can find out where it's coming from or a fix? Thanks!
Garden hose with somebody's thumb on it pointed at the window. Sit inside and look for water leaking through.
Alternatively, use compressed air. Preferably not of the can type. That ****'s expensive.
The other day I was driving with the window down and noticed the same wind noise coming from the passenger side - only much louder of course because the window was down. I took it in to the dealer today and after driving the service manager around he explained that it's probably coming from the wheel well, passenger side. According to him it's a little loose and when I drive fast the wind noise is coming up the side of the car. Makes sense and I'm hoping that will be the end of that. Hopefully this info. can help someone who's having similar problems
On the drive home it was really quiet, so quiet in fact that I wish I had asked them to do both sides because all of a sudden the driver's side is more noticeable. Apparently the inside of the wheel well was not fit very tight so they pushed it back slightly and filled the gap in. Listen carefully and if you notice the same wind noise pattern with the window down that you hear when the window is up, it's not from the window seal.
Deysha
Rando
8/25/21 11:12 AM
