Why does my tire pressure monitor for my 12 5.0 look like this?
Old Apr 15, 2011 | 09:02 AM
unas2k5's Avatar
Isnt it normally a band that goes around the rim?
Are these reusable?
Old Apr 15, 2011 | 09:14 AM
LinT's Avatar
thats what mine looks like to (2010 v6) Its just a different type of sensor. There is a little hole in it that detects the pressure. I had them removed from my old rims and put into new rims... no problems at all.
Old Apr 15, 2011 | 09:23 AM
Scruffy281's Avatar
They switched in 2010. They are reusable.
Old Apr 15, 2011 | 09:25 AM
Modshack's Avatar
Are these reusable?
Most manufacturers have gone to that newer style (no bands) integrated into the valve stem. Re-usable...yes. YOu can buy the re-set tool for around $35
Old Apr 15, 2011 | 09:26 AM
unas2k5's Avatar
My 10 Gt had the band.
Can I put this TPM on 20's?
Old Apr 15, 2011 | 07:22 PM
HoosierDaddy's Avatar
Legacy TMS Member Moderator
FYI: The reset tool is not needed for 2011 and I assume the same for 2012.
Old Apr 15, 2011 | 07:38 PM
bob's Avatar
bob
Yep, the sensor is bolted to the stem, GM was the first to use this IIRC, much better than the sensor that has the integrated metal stem and is bolted to the wheel.
Old Apr 15, 2011 | 07:41 PM
bob's Avatar
bob
At this time I dont think so, would love to upgrade to this since it makes wheel changes very easy (just buy new stems and mount the sensor).
VDO is developing a universal sensor for TPMS applications, I hope when this becomes more popular, a rubber stem mounted VDO redi-sensor can be used in place of the strapped units.
http://redi-sensor.com/
Old Apr 16, 2011 | 06:36 AM
David Young's Avatar
I'm glad My 11 Mustang has the valve stem type. My Dad's 2010 Taurus has the band type (i think i read it in his owners manual).
Old Apr 16, 2011 | 08:41 AM
5 DOT 0's Avatar
I read that with the newer style you need to replace the valve stem. Is that true and if so where do you purchase them?
Old Apr 16, 2011 | 09:41 AM
05stangkc's Avatar
Are these reusable?
https://themustangsource.com/f700/tp...system-471751/
Tons of Info!
Enjoy
KC
Old Apr 16, 2011 | 11:47 AM
5 DOT 0's Avatar
Great info, thanks!
OT have you found the part number for the stock Boss wheels yet?
Old Apr 16, 2011 | 01:06 PM
ZackeryJc's Avatar
The band is the old ones and they started using this within the past few years and yes they can be reusable
Sep 16, 2015 06:44 PM
oldnjguy
Sep 10, 2015 02:39 PM
bconboy
Sep 10, 2015 02:31 PM
Sep 8, 2015 10:45 AM
Cdvision
Sep 5, 2015 05:22 PM
