why do i keep getting locked out of 3 gear
Old Jul 31, 2012 | 04:03 PM
JonW's Avatar
This is one of my favorite vids to explain heel toe driving. I'm posting this because if you watch his shifting hand he doesn't really grip the shifter but uses the heel of his hand most of the time to shift forward and his fingers to pull the shift lever rearward. I still haven't figured out why he has the blue air horn but it's still a good video. I am still trying to get good at heel toe but I'm pretty good at rev matching while downshifting. It's easy in the Mustang because the revs climb pretty fast when you blip the throttle.
I think if you leave the track, you sound the air horn if you're OK.
Old Jul 31, 2012 | 04:08 PM
LLZuB's Avatar
I had issues when I was trying to grip the shifter to slam it into 3rd, but since i've change to technique to palming it and letting the transmission do the work, i've never had issues getting into 3rd
Old Jul 31, 2012 | 04:11 PM
Stevedotmil's Avatar
Off track thing make sense.
Old Jul 31, 2012 | 04:42 PM
falhulk's Avatar
^^This guy......he so funny.....no Skip shift mode on 2013. I'm already trying to figure out how to fabricate a clutch block.
funny? push it to the floor and you will have no problem. clutch blocks are stupid.
Old Jul 31, 2012 | 06:42 PM
I just lol'd
Old Jul 31, 2012 | 10:33 PM
Five Oh Brian's Avatar
Originally Posted by citizen arcane
I've been driving sticks longer than some on this board have been walking on this good earth (learned on a three on the tree) and never have owned an auto - hell even my truck is 5 on the floor. I have no issues what so ever w/ my 6mt on the '13. Using the heel and the palm of my hand I haven't once dropped a shift. Reverse, however ,took a little time to master.
Try shifting repeatedly at redline and you'll start getting locked out of 3rd occasionally. I, too, have been driving sticks for decades and consider myself to be well above average at shifting a manual trans on and off the track. The MT82 in my '11 5.0L shifted horribly until I installed the best shifter assembly on the market (MGW's upper/lower complete assembly).
Old Aug 1, 2012 | 04:11 AM
dafreeze's Avatar
I'll bet you a cheeseburger it's not the skip shift feature or the shifter, although you see there's a lot of guys who will tell you to replace it and/or it's bracket.
But this 6 speed requires more finess/thought than any manual I've ever driven. 2 weeks shy of 53 and driven predominantely manuals, learning on a 4 speed on the column.
Like a few have mentioned, let the centering spring take you to the middle pair of gates. I use an open grip like described above, the heel of my hand, to push the shifter forward, through the 'neutral' position and on up to 3. Never miss a shift. If I try to shift 'up and over' and 'find' 3rd, I'll frequently miss.
Also my clutch pedal needs to be all the way to the floor.
These gates are narrow and when you're getting on it there's a lot of torque twist, not to mention adrenelin.
I also pull back to 4 w/an open grip as well, otherwise I'll have a tendency to pull the shifter towards my body. Quick shifts to 5 take a little finess, but by then you're likely 110+.
And when shifting into or within either of the outside pairs of gates, always counter that spring appropriately. Bummer downshifting from 6 to 5 but hitting 3rd instead.
I've driven the snot out of my car w/frequent launches and wot runs up through 4th. 21K+ miles in 14 months and I've no problem what so ever with this shifter or the transmission.
Rando
Aug 25, 2021 11:12 AM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
boz
Oct 1, 2015 04:47 PM
Rando
Sep 30, 2015 12:28 PM
PonyMuscletang13
Sep 26, 2015 02:33 PM
