why do i keep getting locked out of 3 gear
Old Jul 30, 2012 | 08:00 PM
ckaven's Avatar
Any know how to prevent this?
Old Jul 30, 2012 | 08:03 PM
theACE's Avatar
LOL any more info for us there bud?
It could be skip shift, but idk based on the lack of details we got....
Old Jul 30, 2012 | 08:14 PM
db2797's Avatar
Welcome to the MT82 haha. The only way to prevent it without paying for aftermarket parts is to push the clutch as far as you can to the floor, shift slower and very precise, and shift at lower RPM's.
Otherwise if you want to spend a few bucks, you can start with a MGW or Barton shifter and bracket which will give you about 50% improvements. And then the more expensive option to fully solve the problem is to add a higher quality clutch.
Old Jul 30, 2012 | 08:35 PM
ckaven's Avatar
I got a 2013 and I dont think it has skip shift
Old Jul 30, 2012 | 08:41 PM
Gunny Mike's Avatar
ckaven,
According to the 2013 Mustang E-Source Book:
Skip-shift feature goes from 1st to 4th gear at certain
speeds to help fuel efficiency
I'm not sure if there is a way to disable the feature or not.
Old Jul 30, 2012 | 08:50 PM
kjbuck2's Avatar
You can disable it with a tuner.
Old Jul 30, 2012 | 09:04 PM
KalEl370's Avatar
It might be your technique. Try this: shift from 2nd to 3rd by placing your open palm behind the shifter and let the spring do most of the work while pushing it into 3rd. This helped me out a lot and I have not missed many shifts since. If you are grabbing the shifter and trying to force it in, this is how I would miss and get blocked out.
Old Jul 30, 2012 | 09:06 PM
Frosty the Snowman's Avatar
You can pull the power plug out of the skip shift module. Do a search and you should find a thread with details.
Old Jul 30, 2012 | 09:56 PM
GreenCars's Avatar
I have a 2013 and I only have had problems with 3rd is by me mistakenly going into 5th.. Is this a GT or V6?
Old Jul 30, 2012 | 09:58 PM
Snoopy49's Avatar
The 2012 owners manual talks about the skip shift mode, but it is not mentioned in the 2013 owners manual.
From The 2012 Mustang Owners Manual.
Skip Shift (if equipped) (V8 engines only)
This feature locks out 2 (Second) and 3 (Third) gears for improved fuel economy. If the message center displays 1–> 4 SHIFT, shift the transmission directly from 1 (First) to 4 (Fourth), otherwise you can shift normally. Refer to Message center in the Instrument Cluster chapter.
14 SHIFT FOR FUEL ECONOMY — Displayed on manual transmission vehicles when the vehicle determines that shifting directly to 4th gear from 1st gear will improve fuel economy. Refer to Manual transmission operation in the Driving chapter for more information.
Old Jul 30, 2012 | 10:19 PM
Hytek's Avatar
Is it only under hard acceleration? If yes, then look into a shifter bracket like a Barton or Steeda.
Old Jul 31, 2012 | 05:14 AM
falhulk's Avatar
Umm...you should always push the clutch all the way to the floor. I dont have to shift slowly at all.
Old Jul 31, 2012 | 06:50 AM
Stevedotmil's Avatar
^^This guy......he so funny.....no Skip shift mode on 2013. I'm already trying to figure out how to fabricate a clutch block.
Old Jul 31, 2012 | 07:15 AM
viiStang's Avatar
I've been reading about how crappy the MT82's are but me personally now having close to 1200 miles on my ride, I never had any issues with it. At first it was definitely a bit notchy, but now it's fine. It's not as bad as a transmission as it's made out to seem.
Old Jul 31, 2012 | 08:00 AM
Five Oh Brian's Avatar
Aftermarket shifter is your answer (i.e. MGW or Barton).
Others have mentioned the skip-shift as a culprit, but that has absolutely nothing to do with the 2-3 shift problem that you're having. Skip-shift only messes with the 1-2 shift (making it a 1-4 shift, instead, under light throttle to save fuel).
Old Jul 31, 2012 | 12:30 PM
airoscar's Avatar
you dont even need to get a new shifter, i think a barton shifter bracket for under 100 bux will improve it.
Mine seems to notchy at begining, after 5000km it feels smooth now.
Old Jul 31, 2012 | 12:38 PM
JonW's Avatar
I use the same technique for 3rd and 4th. If I grip the shift ball like I normally would, it's a hit and miss proposition most of the time. So I flat palm it into 3rd and let the shifter find the center detent on its own.
Old Jul 31, 2012 | 01:10 PM
This is one of my favorite vids to explain heel toe driving. I'm posting this because if you watch his shifting hand he doesn't really grip the shifter but uses the heel of his hand most of the time to shift forward and his fingers to pull the shift lever rearward. I still haven't figured out why he has the blue air horn but it's still a good video. I am still trying to get good at heel toe but I'm pretty good at rev matching while downshifting. It's easy in the Mustang because the revs climb pretty fast when you blip the throttle.
Old Jul 31, 2012 | 03:08 PM
citizen arcane's Avatar
I've been driving sticks longer than some on this board have been walking on this good earth (learned on a three on the tree) and never have owned an auto - hell even my truck is 5 on the floor. I have no issues what so ever w/ my 6mt on the '13. Using the heel and the palm of my hand I haven't once dropped a shift. Reverse, however ,took a little time to master.
Old Jul 31, 2012 | 03:39 PM
11SHELBYGT500's Avatar
What's a sticks?
