Why Boss instead of GT-500
Old Mar 28, 2011 | 09:14 PM
The Reverend's Avatar
Why purchase a 2012 Boss instead of a GT-500? When they cost almost the same?
Locally, the Boss can be purchased @ MSRP for $43465 without Brembos.
The GT-500 on X-plan(yes, its available now) @ $45189 with Brembos and an additional 100hp.
2011GT/CS's Avatar
Boss is the new hot thing. That's why
Old Mar 28, 2011 | 09:24 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I guess it comes down to what really strikes a chord with someone. Its what hits you on a personal level and connects with you emotionally. When it gets to that point, the price difference doesn't really figure into the equation for a lot of people.
Then you get into what the person is looking for in a car. A boulevard bruiser that has lots of amenities but still rips and snorts when you want it to, or a more dedicated track weapon with less frills. At the end of the day, they are both great cars, but they fill a different niche and appeal to a different customer base.
Old Mar 28, 2011 | 10:27 PM
The Boss has Brembos.
Old Mar 29, 2011 | 12:12 AM
LEwis26's Avatar
So does the gt500
Old Mar 29, 2011 | 12:33 AM
Big Vito's Avatar
Originally Posted by LEwis26
So does the gt500
Did you read the OP?
Sent from my Droid via iPhone using TMS Forum
Old Mar 29, 2011 | 12:34 AM
Big Vito's Avatar
Where did the x-plan price come from?
Old Mar 29, 2011 | 01:22 AM
Berol's Avatar
This
Two different cars for two different purposes.
Old Mar 29, 2011 | 01:28 AM
tom_vilsack's Avatar
Old Mar 29, 2011 | 07:52 AM
CO_VaporGT_09's Avatar
This:
2011 Shelby GT500 specs:
* 5.4L 4-valve DOHC V-8
* 330 cu. in. / 5,409 cc
* 550 hp @ 6,200 rpm
* 510 lb.-ft. @ 4,250 rpm
* 6,250 rpm redline
* 8.4:1 compression ratio
* Aluminum block, aluminum heads
* 9.0 psi roots-type supercharger, air-to-water intercooler
* Forged steel crankshaft
* Forged aluminum pistons
* Cracked forged steel I-beam rods
* Tremec TR6060 six-speed (3.55 final)
* Weight: 3,820 (56/44)
2012 Boss 302 specs:
* 5.0L 4-valve DOHC Ti-VCT V8
* 302 cu. in./4,951 cc
* Composite shell-welded intake
* Stainless steel tubular headers
* 7,500 rpm redline
* 11.0:1 compression ratio
* Aluminum block and heads
* Forged steel rods
* Tremec TR6060 six-speed (3.73 final)
* Weight: 3,631 (55/45)
Boss: 3631lb/440hp = 8.25 lb/hp
GT500: 3820lb/550hp = 6.945 lb/hp
2012 Mustang Boss 2011 Shelby GT500
302 Laguna Seca
As-tested Price $47,990 $55,330
0-60 mph (sec.) 4.6 4.6
1/4 mile
(sec. @ mph) 12.7 @113.4 12.6 @ 115.8
Skid pad
(200-ft. diameter)
lateral g 0.98 0.99
Slalom, 6x100 ft. (mph) 72.0 70.1
Road course lap time
(min., sec.) 1:26.1 1:25.6
60-0 mph (ft.) 107 110
As-tested weight (lbs.) 3,622 3,808
Because of the lighter weight, it does more with less (literally).
Old Mar 29, 2011 | 08:13 AM
davesvt2000's Avatar
302 Laguna Seca
1/4 mile
Skid pad
(200-ft. diameter)
lateral g 0.98 0.99
You've got most of these quotes backwards, unless you copied and pasted them and the chart didn't come out right ???
Old Mar 29, 2011 | 08:21 AM
straight from Edmund's Inside Line:
http://www.insideline.com/ford/musta...shoot-out.html
Maybe your monitor is set in mirror mode??
Old Mar 29, 2011 | 08:42 AM
11SHELBYGT500's Avatar
This:
* 6,250 rpm redline
* 7,500 rpm redline
* Forged steel rods
302 Laguna Seca
1/4 mile
Skid pad
(200-ft. diameter)
lateral g 0.98 0.99
Some of these numbers are from fantasy land. Whoever did this test should spend more time with the vehicles or stop testing. I guess the GT500 they tested with didn't have the PP package since you put a 3.55 final. Let's not forget that the 5.0 in the boss has been seriously pushed to the limit to squeak out an extra 30hp. For a 150.00 you can easily get another 50hp with a blower pulley. That much power can easily be put to the ground with a few added parts. One last thing, I'm not sure how ford gets it's weight but I've weighed my 500 and it's 3793
That being said it really comes down to which one looks better to you.
"I wanna go fast"
Old Mar 29, 2011 | 09:08 AM
"I wanna go fast"
Very true -- 5.0 magazine just did a shootout of a KB boosted 5.0 and 5.4, and the 5.0 pushes out more HP per psi due to the higher compression ratio. The 5.4 has more potential for top power due to its displacement (though the 5.0 heads flow better).
It comes down to the high revving, lighter feel versus the big brute, high torque but low redline approach.
The top part of this is from a different site -- the Edmund's test was with the SVTPP.
Those weight differences can be a tank of gas...
Old Mar 29, 2011 | 09:17 AM
In your chart It says GT500 first, then 302 Laguna Seca, but then goes on to list As-tested Price $47,990 $55,330, which we know is backwards. Same for weight, G's, slalom, braking, etc.
I see that the Edmunds chart is correct in the order they are presented.
That higher compression ratio will limit it. I don't think they can safely run more than 7 or 8 lbs of boost. While the lower compression 5.4 can handle a butt load. LOL
"I wanna go fast"
Old Mar 29, 2011 | 09:41 AM
See above...
Quite true, they noted that as well. The 5.4 is purpose built for boost with that low compression ratio, and allows more boost, ultimately. But in mildly-boosted applications, the 5.0 wins hp/lb of boost.
The Boss is for the road track, the Shelby for the drag strip, I think.
Old Mar 29, 2011 | 06:56 PM
cnaimo's Avatar
Good luck finding a Boss for MSRP... most dealers are adding $$$ ends up being cheaper to buy a GT500..
Old Mar 29, 2011 | 08:59 PM
Big Vito's Avatar
Already did
Old Mar 29, 2011 | 09:02 PM
FCMalie's Avatar
Originally Posted by Big Vito
Already did
Yea, I seem to remember a thread in the Boss section asking what people were paying and there were quite a few for MSRP.
