Who has the highest mileage AC compressor?
Old Feb 7, 2017 | 01:07 PM
MRGTX's Avatar
A well known and expensive failure on our Mustangs is the AC compressor that often unceremoniously croaks somewhere in the neighborhood of 40k miles.
Mine currently has 32k and works fine, last time I tried it. I don't think that it helps that I use the AC almost never, even in the heat of summer..but it's probably worth mentioning.
How's yours holding up? Does anyone have a super high mileage car without a failure?
Old Feb 7, 2017 | 02:31 PM
tukatz's Avatar
My '14 has almost 50K miles and I leave the AC on all the time, either blowing cold air or hot air as need be.
Old Feb 7, 2017 | 03:39 PM
SpectreH's Avatar
I leave mine on also...55K miles and counting, knock on wood.
Old Feb 8, 2017 | 05:53 AM
Dean Martin's Avatar
116K miles and AC works like a charm. Use it a lot in the summer, pretty humid here in the STL area.
Old Feb 8, 2017 | 12:35 PM
kylerohde's Avatar
113k here - had to replace the evaporator core due to leaking, which was a $2,000 repair since most of the dash had to come out to get it done. Book on that job is 10 hours and it took the mechanic at my dealership 14 hours, apparently, since it was his first time. A/C compressor has never had an issue though.
Old Feb 8, 2017 | 07:35 PM
EF1's Avatar
EF1
I have 73k on mine without a hiccup yet.
Old Feb 10, 2017 | 06:33 AM
MRGTX's Avatar
This is awesome news, guys!!
Very encouraging...
Ouch...that's not so great news.
I sounds like another example of a design that has no accommodations for being repaired. That's just unreal.
Old Feb 10, 2017 | 07:21 AM
dusman59's Avatar
All most all of todays cars are designed with having to remove the the dash or disassemble major components for repairs. Its too bad that taking out a few screws to fix something are gone.
Old Feb 10, 2017 | 02:56 PM
kylerohde's Avatar
Very encouraging...
I mean, it's not a common repair - I don't remember seeing another car with the same problem on here - so I can't ***** too much. Yeah, it sucks I had to pay that much but stuff happens with cars. Just like the ABS/TCS/ASC module going bad on my wife's Mazda3 at 45k. Uncommon but stuff happens.
Old Feb 10, 2017 | 08:34 PM
BackroadGT's Avatar
Almost 42k mi. Used it today, still working fine.
Old Feb 16, 2017 | 08:12 PM
Maych's Avatar
Pretty sad. I'm facing this now at 58k. Diagnostic: ac compressor came apart. Nice... Estimate $1329.06 I so badly want to go aftermarket including the service shop. You all replacing yours with OEM? Knowing the dealers normally charge 70%+ over cost for parts, makes me ill. Valued customer indeed.
Old Feb 17, 2017 | 01:46 PM
kylerohde's Avatar
I don't know that there is an aftermarket option, is there?
Old Feb 17, 2017 | 02:01 PM
berzerk_1980's Avatar
From rockauto.com
Old Feb 18, 2017 | 01:29 PM
kylerohde's Avatar
Originally Posted by berzerk_1980
From rockauto.com
I'll be damned. 50% less.
Old Feb 19, 2017 | 10:36 AM
There was a lot of variance so one must do the search themselves and click info to make sure the right stuff is included... I was just showing that I found something. Seems the Four Seasons part is available at most auto parts stores.
I wonder who makes the OEM part?
Old Feb 19, 2017 | 04:49 PM
Maych's Avatar
For sure. I found the motorcraft compressor and clutch new on ebay from a couple different people. Didn't dig that deep yet to determine if their a vendor or their source, but it did say warranty. To be honest, since Ford has the problem, I'm thinking if they didn't change anything on the compressor, I'd be a fool to replace it with OEM. My local dealer never said anything about the TSB either. I think theres at least a couple including TSB 12-8-14, which is right there and may be contributing to the issue, but dealerships around here just suck. I spent several years as a parts counterman, so I guess for its karma. So I'm still researching to determine what my final plans will be for fixing it. Thanks for all the help and info
Old Feb 24, 2017 | 04:59 PM
Marl_Boro's Avatar
103k and is still ice cold
Old Mar 1, 2017 | 07:24 PM
13_ImpactBlue_GT's Avatar
85000 and change still works as advertised.
Old Mar 2, 2017 | 05:52 AM
MRGTX's Avatar
You have 103k miles on your 2014?
Old Mar 2, 2017 | 07:41 AM
Marl_Boro's Avatar
Why yes I do lol
