wheel setup help and suggestions
Old Jun 24, 2015 | 08:26 PM
Nick Katz's Avatar
Hey so I just ordered my amr dark stainless wheels for my 2013 5.0 from American muscle. I got 20x8.5 in the front and 20x10 in the rear.
I was wondering what would be the widest tire I could run in the rear without rubbing issues.
Car is at stock ride height but I'm going to be getting springs soon, so I also wanted to know which springs you guys recommend.
Post pictures of your setup if you have something similar
Thanks!
Old Jun 25, 2015 | 04:05 AM
Big Poppa's Avatar
I would go with nothing wider than a 285, but I believe you can go as wide as a 305 without problems. As for springs I recommend Steeda Sport springs. You might want to think about changing shocks and struts while you at it. I recommend Koni Yellow.
Old Jun 25, 2015 | 07:03 AM
shayner's Avatar
Thanks!
the widest tire you can go with is 315 , depending on your offset though.
with the 10.5 , like mine, im runnign a 305/35/20....no issues.
with a 1.5 drop in the back a 285/30/20 , the tire is small and does not fit in the wheel whell enough.
Old Jun 25, 2015 | 10:34 AM
Nick Katz's Avatar
Awesome thanks for the reply! I'll definitely check them out!
Old Jun 25, 2015 | 10:38 AM
dohc97's Avatar
I also have a 10.5 wheel with +45 offset. I am using Eibach pro springs with a minimal drop. Can I use 305/30 tire?
Old Jun 25, 2015 | 08:50 PM
wlarryf's Avatar
I've seen some Mustang that has 315's on 10.5 wide rims and they are flush with the lip.
Old Jun 25, 2015 | 08:52 PM
Nick Katz's Avatar
Do u know if the 315's would fit amr 20x10 with maybe a 1.5-1.8 drop in the rear
14BlackGT
Aug 26, 2015 12:33 PM
MRGTX
Aug 21, 2015 08:49 PM
ClayP
Aug 3, 2015 09:00 PM
Jul 17, 2015 05:40 PM
