Well, so I missed...
Old Aug 25, 2010 | 07:36 PM
Turn3's Avatar
... a shift tonight. Very embarr***ing.
From second to third, tach went red and hit 7000.
Old Aug 25, 2010 | 08:12 PM
Freshmeat's Avatar
Try downshifting to second instead of fourth at 75mph in an emergency attempt to avoid a massive collision. Luckily I didn't come fully out of the clutch when I realized my error and corrected it.
The wreck was avoided.
The waste of life in the Pontiac Parisienne on 26" wheels made his way along.
My entire drivetrain is likely upset with me, although there are no signs of damage. Hopefully nothing happens as a result of this.
Old Aug 25, 2010 | 08:28 PM
Ltngdrvr's Avatar
Don't even think about downshifting in a situation like that, just stomp the whoa pedal and clutch it and hang on.
Old Aug 25, 2010 | 08:29 PM
Ltngdrvr's Avatar
We've all done it, most have done it many times over the years.
Old Aug 25, 2010 | 08:34 PM
montreal ponies's Avatar
Fingers crossed as far as i'm concerned so far.
Old Aug 25, 2010 | 08:36 PM
Freshmeat's Avatar
At least you weren't at the track where people were outright watching you! I miss shifts once in a while and all my vehicles are manual, including the Kenworth I drive 60+ hours a week.
Old Aug 25, 2010 | 08:45 PM
OAC_Sparky's Avatar
Yeah, this is worse than a missed shift; a missed shift hits the limiter and you're done, you pop that clutch out in the wrong gear and you've overshot redline by 1-2000 RPM and goodnight Irene.
Good that you caught it in time, I did it once and it was pretty damned scary when the engine yelled at me...
Old Aug 25, 2010 | 08:49 PM
Turn3's Avatar
Worse, I was with my wife.
DISCLAIMER: For you guys at the Ford Warrenty department, this was just a joke. If this had been an actual occurance, I would've kept it to myself.
Old Aug 26, 2010 | 06:08 AM
Freshmeat's Avatar
Now that's just funny!
Old Aug 26, 2010 | 07:14 AM
jeff s's Avatar
When's that new Steeda shifter coming?
Old Aug 26, 2010 | 10:01 AM
pony racer's Avatar
did that in my camaro in 1991 went from 3rd to 2nd @100 mph.. dont ask..
8 of 16 valves bent.. car still ran 14.6 in the 1/4 that day.
idled like it had a huge cam..
Old Aug 26, 2010 | 10:12 AM
Double-EDad's Avatar
Done it a couple of times in 2500 miles so far, once with a somewhat coarse grind. No harm no foul, but maybe a couple of extra particles clinging to the magnetic drain plug on the tranny. The 2-3 shift isn't the quickest or smoothest anyway.
BTW, love your avatar. It looks like the other half of the same car as mine.
Old Aug 26, 2010 | 10:47 AM
Freshmeat's Avatar
I'm gonna be sick at the thought of bent valves.
Old Aug 26, 2010 | 10:55 AM
emilram11's Avatar
I've been having trouble going from 4th to 5th. I end up in 3rd instead. That's not too bad I think but its a little frustrating.
Old Aug 26, 2010 | 11:06 AM
Turn3's Avatar
I noticed that after doing mine! I started with the enitre front and ended up with what "we" got based on the pic size. I'm not sure why I picked the passanger side though.
Any copyright infringment on my part?
Great idea, one last mode for the end of summer. The Wife shouldn't be to upset with that change based on the ribbing I received.
Old Aug 26, 2010 | 11:30 AM
Automagically's Avatar
Don't feel bad, I was about to pass by doing a 6-4 shift last night and even though the shifter in my Honda centers I still didn't pull it off. I just got embarassed, put it back in 6th and putted along. Sure made a lot of noise but wasn't successful. Still working on it.
Old Aug 26, 2010 | 11:51 AM
Don't fret. It was in a Camaro.
Old Aug 26, 2010 | 12:01 PM
WhiteBird00's Avatar
try this... instead of putting your hand over top of the shift ****, turn your hand so that it is heel up with the palm pressing on the side of the **** at about the 7:00 position then push forward and to the right. You'll hit that 4-5 shift every time.
Old Aug 26, 2010 | 01:35 PM
emilram11's Avatar
So my hand should be like a handshake position with my palm slightly angled ? - Thanks for the tip! I was subtly looking for advice!
Old Aug 26, 2010 | 01:45 PM
Not quite... your hand will be in a handshake position but upside down (with the heel up and the thumb pointing down). Think of the Karate Kid deflecting kicks. This allows you to push the shift **** forward and away from you all in one motion so that there is no chance it will go into 3rd instead. It might feel awkward the first few times you try it but once you get used to it you'll never miss another 4-5 shift.
