weird oil dipstick problem
Old Oct 15, 2020 | 04:17 PM
Winkawak's Avatar
For some reason when i went to check my oil today, last couple inches of dipstick does not go in smoothly. It felt like something metal was in the way and rubbing against it, have to force it alittle in order to seat the dipstick.
Old Oct 15, 2020 | 06:02 PM
SpectreH's Avatar
Did you try removing, rotating 180 degrees, and reinserting?
Old Oct 15, 2020 | 07:20 PM
Winkawak's Avatar
Yea i tried that too, still the same. Is dipstick tube damaged? how do i replace it? Is it possible im scraping against engine parts when inserting dipstick
Old Oct 15, 2020 | 11:57 PM
houtex's Avatar
The dipstick tube is a replaceable unit, mounted with one bolt on the left side of the engine, and then just 'shoved' into the engine block with an o-ring on it to seal from an oil leak there. The dipstick has an o-ring on it as well that provides both a seal and resistance to blowing out/escaping the tube.
The stick doesn't contact any engine pieces, and if it did, it'd get slapped away or beaten into submission, the aftermath pieces would then lie at the bottom of the pan. It is also sleeved and guided by the tube to specifically NOT contact the internal parts, just stick right into the oil pan at the location needed to get the level.
It's entirely possible the o-ring on the dipstick is hardened and is not compressing to fit into the tube. Removing it would provide the answer, if the stick goes in smoothly, that was the problem, replace the o-ring as needed. If it doesn't, then you may need to remove the dipstick tube and inspect both it and the hole it goes in. Something may have gone in the tube while you weren't looking... Or, one would hope not, something is lurking in the oil pan where it shouldn't be...
As indicated by the question asked earlier, turning it 180 for some reason might work, and that's probably the stick's o-ring to blame for some of that, as it ages and hardens and conforms to the tube.
I hope that helps. Very odd situation, that. Good luck!
Old Oct 16, 2020 | 12:24 AM
Winkawak's Avatar
Logically i was also thinking it shouldnt contact any parts inside the engine, but when i looked carefully i see a couple light scratch lines on the dipstick few mm above the top fill hole. Is it possible this tube broken off and now when i insert dipstick its poking at a part because it does feel like im making contact with metal. Dipstick hole seems like just a hole with nothing else at the opening. I have searched everywhere trying to get an image of 11'-13' dipstick hole to compare on what im missing. Anyone nice enough to take a picture of theirs?
Old Oct 16, 2020 | 10:41 AM
houtex's Avatar
Edit: Ah. Ok, after all this searchin for the past couple of whiles... found it on another page in another forum which I won't link. But there's a 6g involved... Search for '2015 Mustang 5.0 dipstick tube' and you'll get there.
That tube locks in with the valve cover. And it can be broken semi-easily, apparently. So a full inspection of that tube is required here. Perhaps when a valve cover was removed or something they didn't get it back in right. In any event, still gonna have to get dirty, looks like. And/or need to pull the oil pan because pieces in it, potentially... You might wanna take it to a shop, pulling the pan is no joke. Nor is a broken dipstick tube, apparently, I seen some videos now... I mean, I'm not afraid, just... I recently did the pan drop thing and I really don't think it much fun.
Remainder is archivalish and related, so there ya go. Hope that helps.
Ok, new info to me... this is... strange...
https://www.fordpartsgiant.com/parts...3z-6754-a.html
https://www.tascaparts.com/oem-parts...tube-br3z6754b
That's the actual tube. For a 13 GT anyway. And it's straight. And it doesn't have an o-ring. And I'm confused now. Weird looking tube. Looks *very* easy to come off the hole it's supposed to be in on the block. I mean, other than some sorta locking thing/ring at the top, maybe? I don't see any fastener to keep it where it's supposed to be, unlike the 4.6L's which is metal and has a mounting bracket on it. So maybe that's all that's happened here. The tube came off, the stick is hitting the block/pan and you can't get it to seat that way. Go under the car and have a look. (S
Otherwise, I'd take the tube off (the oil is below the tube mount in the block, so you won't lose oil) and see if the stick goes in the tube off the car. If it does, you have a mounting issue or there's something in the block that's gone wonky. An inspection camera or taking the oil pan off is the next step.
I therefore sincerely hope it's the tube's somehow got disconnected and you 'just' need to reconnect it. And then change the oil immediately because who knows what's gotten in the open cavity since that tube's come off. If that's what happened.
Just... You're gonna have to get dirty though, looks like...
Old Oct 17, 2020 | 06:33 PM
Winkawak's Avatar
I noticed something while looking into this situation today. I noticed if i insert the dipstick side with lettering facing me vs the lettering side away from me, i get different oil reading about 2mm difference.
d_bone33
Feb 1, 2016 12:17 PM
Black Stallion
43
Dec 16, 2008 09:57 PM
topkho
Feb 11, 2008 08:56 PM
John SCB
Nov 23, 2005 08:27 AM
AircraftTech
Jun 11, 2005 04:19 AM
