Weight of 2010 Mustang
Old Nov 17, 2008 | 01:36 PM
Cobra 2997's Avatar
Anybody heard anything about what the 2010 'stang will weigh ?? Just curious...
Old Nov 17, 2008 | 01:41 PM
Pwny's Avatar
I believe they said it would weigh less, but by how much, nobody knows.
Old Nov 17, 2008 | 04:03 PM
SuperSugeKnight's Avatar
My guess it'll weigh the same.
Old Nov 17, 2008 | 04:23 PM
TonyN's Avatar
I agree. Maybe a smudge more with the new equipment, stability control, safety equip, better interior materials and ect.
Unless they went with aluminum suspension component (control arms, spindles, k-member, ect = me dreaming...lol).then I doubt there will be much loss in weight since its still the same car. Couldn't imagine them being able to make it lighter without loss of structural rigidity and strength either. Which is one of the reasons the S197 is such a great car.
Old Nov 17, 2008 | 05:56 PM
Boomer's Avatar
From what I remember it was targeted to lost some weight (some could be 50-150 lbs...)
but i wouldn't expect a miracle
Old Nov 17, 2008 | 06:00 PM
max2000jp's Avatar
GVW is 4620, per KC's spec. It looks like the car gained a little bit of weight if you compare GVW's.
Old Nov 17, 2008 | 06:03 PM
sgt d's Avatar
may be a dumb question but what is the gvw rating?
Old Nov 17, 2008 | 07:13 PM
Boomer's Avatar
Yeah..it weighs.... 4620lbs....
Old Nov 17, 2008 | 08:09 PM
TonyN's Avatar
GVW is gross vehicle weight. It is the maximum loaded weight of a vehicle (cargo, passengers, fuel & ect.... including it's own weight).
Old Nov 17, 2008 | 08:53 PM
Mossberg's Avatar
From Ford press release
One important thing that hasn't changed much is weight. The 2010 V6 Mustang only picks up 15 lbs compared to the 2009 model, while the GT climbs just 35 lbs. That means Mustangs still have an advantage of about 400-500 lbs over the new Camaro and even more compared to the larger Challenger.
http://www.autoblog.com/2008/11/17/l...ally-unveiled/
Old Nov 17, 2008 | 10:31 PM
Good to hear. Weight gain is most likely just some updated safety features.
Old Nov 17, 2008 | 10:39 PM
3Mach1's Avatar
Edit for not reading couple of posts up.
Old Nov 17, 2008 | 10:43 PM
Zastava_101's Avatar
TMS Post # 1,000,000
Serbian Steamer
Still a lot lighter than both Camaro and Challenger.
Old Nov 17, 2008 | 11:27 PM
REDFIRESNAKE's Avatar
I thought the new Camaro SS was in the 3700 lb. range.
Old Nov 17, 2008 | 11:43 PM
TTS197's Avatar
Curb weight (lb/kg):
3750 / 1705 - LT automatic
3741 / 1700 - LT manual
3769 / 1713 - LS automatic
3780 / 1718 - LS manual
3913 / 1779 - SS automatic
3860 / 1755 - SS manual
Old Nov 18, 2008 | 01:14 AM
m05fastbackGT's Avatar
From my understanding, Ford wasn't going to include electronic stability control, until towards the end of 2009
Old Nov 18, 2008 | 04:29 AM
holderca1's Avatar
I guess it was ready to go at launch. You can turn it off if that is your concern.
Old Nov 18, 2008 | 11:56 AM
Ministang's Avatar
I'm not aware of any updated safety features that were mentioned except for stability control, and that is mainly software. I'd think that much of the weight comes from new standard features and options. Some of it is probably from the larger wheels. Generally as wheels increase in diameter, weight goes up as well. The 18" wheels in 2006-09 weighed 14 lbs more (for all four) than the standard 17" wheels, and the 18" tires were 8 lbs heavier (2 lbs each). 18" wheels are now standard on the GT with 19" wheels optional.
Old Nov 18, 2008 | 12:35 PM
Mossberg's Avatar
More insulation was added to dampen and quiet road noise for 2010. So that, plus the Bullitt suspension pieces (strut tower brace), better interior materials, and the bigger wheels should roughly equal the weight gain.
Old Nov 18, 2008 | 01:02 PM
Phorty's Avatar
Just curious, what does a typical 2005-2009 GT weigh? I had mine on a scale recently and with an empty tank of gas, it was 3280- which seemed low to me.
