vibration with my radials
Hey guys, i just bought a couple of race star wheels and MT radials. Over the weekend i had the tires mounted onto the wheels and balanced at a local shop, i brought the tires home and put them on the myself, took the car for a spin and i noticed vibration at all speeds especially over 65mph. I've never had drag radials before and wasn't sure if this is normal for them.
Today i took the driver side tire off and noticed that wheel has more weights than the passenger side, not sure if that anything to do with the vibration (oh and they are sticky weights btw) should i take the tires back and have them re-balance the tires, or is this normal?
IMO some of these cars don't like other wheels besides stock. My car has had vibration issues since I got 20" wheels. Nobody has ever been able to completely cure it. Several road force balances and 3 different sets of tires. Also mine has different amount of weights on different wheels. Two of the wheels have no weight and other two have stacks of them in spots.
I looked for those a long time ago and didn't see any but I can't remember if I checked all four tires but I know for sure I checked two and I asked one of the shops that did a balance to check. Whether they did or forgot I don't know. Might ought to check into that again
Yep. Check the washers against your rotors. Also make sure you torque them in a star pattern. Sounds like they are balanced just on the inside of the wheel which is not as true a balance but it should be sufficient. Does the vibration get better as the tires heat up? Some develop flat spots till they heat up.
