tires size
tires size
I got a Mustang GT 2014 base model no brembo brakes.. just got some aftermarket rims for it, str607 cv3s 20in 9 front and 10.5 rear 30 offset front and 35 back. can I do 295/35/20 tires? or 285/35/20 is that the wides and bigger I can go? I want to do the 35 ratio so i can fill the gap cuz i dont want to lower the car and i think the 30 ratio is two small? Or is it best to go with 295/30/20 front and 255/35/20 front? Why do people always go with a lower ratio on the back and higher in front? I really need help with this.. thanks
295s are going to be too wide for 9" but ok on the 10.5" wide wheels.
This might help...
http://www.tirerack.com/tires/tirete...e.jsp?techid=7
keep in mind that if you deviate from the stock diameter, your speedometer will be off...
Personally, I'd call Tirerack and tell them what you're trying to do.
This might help...
JonathonK
7/27/15 07:35 PM
