Tires, which ones are quiet?
I only have about 9,500 miles on the stock 18" Pirelli AS's but the noise they make are driving me crazy. After about a 80 mile round trip drive today, I was ready to park the car and walk away.
I'm pretty sure it's the tires making the noise and not some part of the drivetrain because on certain road surfaces, the noise is not as pronounced.
I'm probably going to have to replace these way before they wear out and want some opinions on a quieter tire to replace mine with. I want something that is not going to be making excessive noise with only a relatively few miles on them. Thanks for any suggestions.
Wayne
Wayne
I have had the Michelin pilot as3s on my car for 6 months. They are all seasons and they grip pretty well and are still quiet. I bought them on a recommendation from a tms person.
This. Pretty much any Michelin is going to be quieter than the equivalent...any other brand...in the same class. For whatever reason, they are almost always quieter and last longer than every other tire in the same class.
I also have the Michelin Pilot A/S 3's and they've been awesome tires. If you want to stick with all seasons they probably are the way to go. I really haven't noticed much road noise at all and they grip well. The road noise on my Dad's 5.0 with the P zeroes is annoying.
But so far I couldn't be happier.
I currently have the Michelin A/S 3 and have owned the Cooper RS3-A in the past. They are both good choices for a quiet ride and are in the ultra high performance (UHP) category for all-season tires. Tire Rack has several UHP tire brands to compare:
http://www.tirerack.com/tires/survey...jsp?type=UHPAS
I’ve had the Yokohama YK580 (all-season) and they were quiet compared to the stock Michelin green-x tires.
Thanks everyone. I have run Michelin tires on my two trucks and they have been very good so I will definitely consider them.
Right now the noise is so bad that I don't even want to drive the car. That is how annoying the sound has become. The only way I can stand it is to drive with both of the windows open and the radio on so the noise is masked.
I'm assuming there are no warranty available for this issue. I need to check to see exactly what the warranty is in regards to the tires as this is one thing I did not read about. Thanks again.
Wayne
Wayne
I have the same problem with tire noise but my car is only a week old so I'm just gonna have to deal with it for a little while. I like the DWS so they'll probably end up being my replacement tires when the time comes.
The DWS are another good all around tire, quiet too. I'd stay away from the DW's.
I've had Michelin Pilot AS 2 19" on the car just over 20 k on them. Rotated every 7000. They are still quiet and handle well in both the cold and warm temps. The AS 3 are probably even better.
I remember we talked about that before. My own personal experiences with them. I know you've had good luck with them, but if you read the reviews, the DW's are far more "hit or miss" compared to the DWS. I'd just go elsewhere in that class/price range. If you want more all weather capability, the DWS is a good selection. If you want more dry weather with the occasional drive in the wet, I'd look at other tires before the DW's. From my personal experience with them...
Today I put the rear end of my car up on jack stands and let it run in Drive to see if I could hear anything unusual. Giving it gas just made the brake light and other lights come on in the dash plus I couldn't hear anything over the exhaust so I just let it idle in gear.
With it idling in gear with the wheels turning and me half under the back of the car, I could not hear anything abnormal from the rear end or driveshaft.
I then started looking at the tires and wheels themselves as they turned and noticed that both rear tires had a slight wobble to them like they were slightly out of round. Looking at the tires from the back, it looked like the tread was slightly moving side to side.
The wheels themselves didn't seem to be doing this so I don't think it's an axle thing or improperly mounted wheels.
Could what I was seeing be the cause of the noise I'm hearing? I didn't jack up the front to spin them so they may be doing the same thing.
Any opinions would be welcome.
Wayne
Wayne
Wayne
Wayne
The noise I'm hearing is more of a hollow roaring sound. It's a constant sound until you come to a stop.
I've also heard that the Nitto's are good.
Today I drove my fiancée's 07GT with the factory 17" Pirelli P Zero Nero tires on it and her tires have none of the noise I'm hearing on my car. Her car and tires only have 16,500 miles on them.
I keep going back and forth on whether or not it's a tire issue or a rear end/driveshaft issue. Maybe the rear end and or driveshaft isn't making noise at lower rpms but is at higher ones? Is that possible?
I can't get any help so far at the dealership so I may try a different one and see what they say.
Wayne
Wayne
