Tire blowout on rear 19"
Old Oct 29, 2014 | 12:47 PM
Moejoe_989's Avatar
Little backstory to get everyone up to speed.
Purchased a new mustang with the 19" 5 spoke wheels in late September of 2013.
Bent my rim a month later and didn't want to dish out $1200 for just the rim from ford.
I drove around in the spare for about 2 weeks, then put winter tires on the rear of the car, BUT I went through 2 locking keys because the lug nuts were put on with an impact wrench and couldn't get them off myself.
Fast forward to June 2014. I took the car to the dealership and had them break those locking lug nuts off, but stupid me I kept driving with my stock 19" tire on the driver side rear, and an 18" snow tire with bigger profile on the passenger side rear.
Anyway, I guess my tire screamed "I've had enough"
Because this passed weekend while cruising home I suffered a blowout.
The middle of the tire looks as bald as George Castanza from Seinfeld.
My brother gave me **** because he thinks it's from doing burnouts all the time (which I wasn't really doing) and that's why my tire wore thin in the middle.
Thoughts?
Attached Thumbnails Tire blowout on rear 19"-image-1881234670.jpg   Tire blowout on rear 19"-image-1577537643.jpg   Tire blowout on rear 19"-image-4292518429.jpg   Tire blowout on rear 19"-image-317337494.jpg
Old Oct 29, 2014 | 01:20 PM
Critical Mass's Avatar
Under normal circumstances I'd say the tire was over-inflated. But in your case, so many things gone wrong. lol.
Old Oct 29, 2014 | 01:44 PM
Moejoe_989's Avatar
It's a steep learning curve that's for sure!
Running two different sizes?! I don't know why I did that for so long.
It's just so **** difficult to find those rims. Even on EBay. But they won't ship to canada a lot if those buyers.
I'm thinking I might just go aftermarket. But I have 3 great condition rims with 3 great tires, and one ****ty rim with no tire. So can't really sell just 3 rims
Old Oct 29, 2014 | 04:51 PM
dmichaels's Avatar
Looks like the middle of the tires have no tread? Hard to tell.
What do your other tires look like?
Old Oct 29, 2014 | 04:54 PM
14Glassback's Avatar
Might want to change the fluid in the differential too... Sounds like you had it working overtime...
Old Oct 29, 2014 | 05:04 PM
Moejoe_989's Avatar
My other rear tires look fantastic-ish.
I assume it's from the different sizes of he two rear tires putting a weird angle on my "stock" Pirelli?
I'm thinking of taking it in for a yearly/winter service and then storing it.
I have notice fluid residue on my rear diff at my oil changes, but never any leakage or puddles on the ground.
I assume it's the valve sweating?
I had my rear pinion seal replaced due to a leak from the dealer at 8,000 kms. Car is currently sitting at 20,500.
Old Oct 29, 2014 | 05:09 PM
Moejoe_989's Avatar
Winter tire that was running opposite the stock Perilli
Attached Thumbnails Tire blowout on rear 19"-image-722005548.jpg   Tire blowout on rear 19"-image-758132447.jpg
Old Oct 29, 2014 | 05:10 PM
Moejoe_989's Avatar
Stock Perilli with 20,500 kilometres and 2 runs down the drag strip.
Attached Thumbnails Tire blowout on rear 19"-image-2708563346.jpg   Tire blowout on rear 19"-image-2560530991.jpg   Tire blowout on rear 19"-image-3473452204.jpg   Tire blowout on rear 19"-image-3926598537.jpg   Tire blowout on rear 19"-image-1802151196.jpg
Old Oct 29, 2014 | 05:17 PM
dmichaels's Avatar
wow your pirelli's are destroyed
Old Oct 29, 2014 | 05:22 PM
GrnT's Avatar
Think of the stress your axel may have been put through. That can't be good with different sized tires.
Old Oct 30, 2014 | 05:05 AM
David Young's Avatar
I bet you need to have your rear end rebuilt.
Old Oct 30, 2014 | 09:49 AM
TheReaper's Avatar
Where I live it's against the law to drive on tires that worn out.
Old Oct 30, 2014 | 12:16 PM
Moejoe_989's Avatar
That's only the one tire.
My rear axle was already replaced because I hit a curb last year and it bent my rim and bent my rear axle.
Old Oct 30, 2014 | 04:10 PM
TheReaper's Avatar
You need to buy and learn how to use one of these.
Old Oct 30, 2014 | 05:15 PM
Moejoe_989's Avatar
I don't disagree. There's a lot of things I need to do better. Check my oil more frequently. Usually it's once a week but sometimes
It'll slip to every 2 weeks.
Need to use a tire pressure gauge as well.
I feel like a goon for running that stupid setup for so long and possible causing damage.
I just don't know what to tell the dealership to look for when they give my car the yearly maintenance inspection.
Old Oct 30, 2014 | 05:36 PM
TheReaper's Avatar
Don't rely on the Dealership, educate yourself and know what to do in the future. That's why you are here, to get knowledge from people who are in the know.
Old Oct 30, 2014 | 06:02 PM
Moejoe_989's Avatar
I appreciate the help!
I'm sure all I did (hopefully) was prematurely wear out the tire.
Oh well, I'm in the market for new rims and rubber this summer anyway!
Old Oct 31, 2014 | 08:42 AM
JoeMidnight's Avatar
you can sell 3... lots of people would want to pick up a single rim as a spare
Old Nov 4, 2014 | 03:27 PM
Moejoe_989's Avatar
I spoke with my friends dad who is way more knowledgable and he's fairly certain the tire was over-inflated which would cause that premature wear in the centre of the tire like that.
Old Nov 4, 2014 | 04:36 PM
Noilly Pratt's Avatar
I would have a trusted shop open up the rear end and check to see if the gears are OK and not prematurely worn. Or at the very least make sure you listen for any weird whine or noises coming from the rear.
What you did would put undue stress on the assembly, but it is pretty stout so you might come out OK.
A lesson learned and hopefully you come out of it with little damage to the drive-train.
