To those with 3.73 gears...
Old Oct 25, 2014 | 12:42 PM
Mustang Coyote's Avatar
What kinds of sounds so you hear with these in the very low (500-1500) and higher up (3500+) RPMs. I hear an almost rattle like noise that is coming from the rear when I go to take off in 1st in a low RPM(differential?). And higher up I hear a grinding noise around 3600 that is around the transmission area (clutch?) also, when I go to accelerate fairly hard, the car feels as it is almost bouncing back and fourth during acceleration sometimes (clutch slipping with 50K on stock one?). Please give me your input on my symptoms and any you might have as well. I want to know if it's normal or needs to be taken in. Thanks!
Old Oct 25, 2014 | 04:02 PM
HizliBullet's Avatar
after my second service at 10,000 miles i began to hear a whine although i think it may be coming from the engine..sounds like a high pitched whirring becoming low pitched as i slow down...
Old Oct 25, 2014 | 05:06 PM
Varilux's Avatar
I've never heard anything from my 3.73 differential (knock on wood). I have heard a slight high whining from the MT-82 tranny, which I imagine are the sync gears, but nothing out of the ordinary.
I eventually plan to install the GT500 rear brakes (with their larger discs), which will involve draining and replacing the diff fluid. Hopefully, I don't induce any noises in the process!
Old Oct 25, 2014 | 05:13 PM
Krohn's Avatar
Honestly, no. That sounds abnormal. The only sound I hear is the torsen diff, I've been told. Its sounds like a dyno wheel as soon as the peak is complete on the whine down.
Old Oct 25, 2014 | 05:52 PM
skramblr's Avatar
The torsen diff on the my track pack car definitely make some whining noises I didn't have on my other GT.
Old Oct 25, 2014 | 10:01 PM
5.M0NSTER's Avatar
I've had a gear whine on my GT TP from delivery. It was very noiceable at first, and after a few hundred miles 70% of it went away. What's been left is a very quiet, fast w-r-r-r-r-r-r every time the car is between 62 and 70mph. Regardless if I'm in 6th, 5th, or neutral. That's how I know it's gear whine. Speed dependent, not transmission gear or engine speed dependent.
Your issue doesn't sound good though. You should have your dealer look into it.
Old Oct 26, 2014 | 09:24 AM
wiz_of_wuz's Avatar
3:73 here and no problems or noises
Old Oct 27, 2014 | 04:56 AM
Kestral's Avatar
I had a slight whine with my 2013 GT MT when I bought it used from a dealer with 12,000 miles on it and by 15,000 it was quite noticeable. I had the dealer check it out and sure enough it needed a rebuild. All internal rear end parts were replaced according to the work order and it is perfect now. And yes I have 3:73's
screaminyellin6
V6 Performance Mods
Nov 30, 2005 10:03 PM
screaminyellin6
V6 Performance Mods
58
Nov 25, 2005 07:41 PM
MSP
V6 Performance Mods
87
Oct 27, 2005 08:42 PM
z71mudder199
Feb 23, 2005 07:15 AM
