thinking of a 2013 combo.
Old Jan 17, 2012 | 03:29 AM
nickt916's Avatar
have been thinking on a combo set up for the 5.0 that ill hopefully have when it comes out.
2013 Base GT model
Grey
Recaro seats
non leather Boss steering wheel
red wilwood calipers and drilled slotted rotors all around
RTR 19s
275-35 245-40
boss front bumper with lip (unless boss lip would work with GT front)
satin black bottom skirts (like on 2011-12 models)
satin black tail panel (maybe remove the GT cap badge if possible)
2013 GT500 rear bumper with defuser
2013 GT500 quad exhaust mufflers
2013 Shelby spoiler
what do you guys thinking, opinions, advice? ill try to photo shop some things later if i have time.
lower the car a bit
Old Jan 17, 2012 | 08:31 AM
BlackMamba03's Avatar
Why wouldn't you put 275's all around? The RTR wheels are 19x9.5. A 245 tire doesn't make sense for that.
Old Jan 17, 2012 | 10:21 AM
2 Go Snake's Avatar
Smile
By all means get the Ford Motorsport Boss 302 quad exhaust. Otherwise, sounds like you have quite the plan.
Old Jan 17, 2012 | 04:17 PM
nickt916's Avatar
i thought the RTR wheels are 9.5 rear and 8.5 front? won't 9.5 all around make it harder to handle or the fronts will stick out to much or something?
the 2013 boss doesn't have the quad just dual, gt500 quad looks pretty mean and i think it will sound much better than the stock 5.0 exhaust or maybe any other aftermarket exhaust for the 5.0.
i was thinking to also maybe do a boss intake on the 5.0 but not sure how much drama that is just yet, might be an easy swap for few exhaust HP
Old Jan 17, 2012 | 06:14 PM
99mstng's Avatar
RTR 9.5" all around. It will be even with the rears. Also, boss does have a quad exhaust duals in the rear and them two for the side pipes.
Old Jan 17, 2012 | 06:30 PM
2010MustangGT's Avatar
whats the reasoning for the cross drilled & slotted? Looks? Or are you tracking?
Old Jan 18, 2012 | 06:11 AM
nickt916's Avatar
can you show me a picture of this please, have only seen 2013 bosses with dual
some tracking, mostly for looks tho, i might just go with the slotted
Old Jan 18, 2012 | 08:34 AM
Check this link out for pictures of the RTR wheels.
http://www.latemodelrestoration.com/...harcoal-Wheels
Old Jan 18, 2012 | 08:38 AM
I was thinking to also maybe do a Boss Intake on the 5.0 but not sure how much drama that is just yet. Might be an easy swap for few exhaust HP.
It's an easy swap. Yes, you'll gain HP. The one thing you should know is that unless you're going to be running at 7,000RPM or higher most of the time, you'll never get 100% out of the intake.
Old Jan 18, 2012 | 04:28 PM
99mstng's Avatar
Do a search or go to fords website. The pipes come out under the sides and you can't see it unless you look under the car.
Old Jan 18, 2012 | 06:37 PM
nickt916's Avatar
i gotcha, so the dual is visible and the other pair is not visible, I'm loving the shelby GT500 quad exhaust look over the dual, thats why i wanted to do the swap, mainly for the meaner look, and different from any other mustangs
Spiker52
Jul 4, 2018 06:34 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
