Temp Gauge - Outside Air
Has anyone else had an issue with the temperature gauge running way high? If I am in traffic the gauge reads anywhere from 105-120F. Obviously it is hot in Savannah, Ga but, not that hot.
Thanks in advance.
Thanks in advance.
If so mine does that randomly. I've chaulked it up to its possibly broken or haunted.
Mine read a 109 degrees when i turned the car on this morning. and i live in Michigan.
I will look at that. The very first week that I owned it someone backed into me and the front end had to be repaired. I wonder if they put it back in the wrong spot or have it facing the wrong direction?
Does the exhaust from the vehicle in front of you effect the sensor as well?
I've noticed in traffic that a vehicle in front of me with rearward facing exhaust can heat the air that is being pulled by the radiator and heat exchanger on my car.
Its not a lot mind you, but I've noticed a two degree difference between me being first at the tree compared to me being on somebody's six in traffic.
I found mine just dangling after a front bumper repair, and it was reading very high on a sunny day. remounting it in the correct spot returned accuracy. It needs to be in the forward airstream and shielded from the pavement to give a good reading.
I will have to look at it when I get home. :-)
I am guessing that you have to get to it from below?
Well I found it yesterday. I had it up on a lift (getting new wheels/tires) and I asked if I could pull the cover off the front. What I found was the sensor was stuffed into the housing for the radiator. There wasn't any damage done. What troubles me is when I brought into Ford they said they could not find the problem. Which means they didn't even look being that it was so obvious.
