Temp Gauge - Outside Air
Old May 13, 2014 | 01:58 PM
bjbsav's Avatar
Has anyone else had an issue with the temperature gauge running way high? If I am in traffic the gauge reads anywhere from 105-120F. Obviously it is hot in Savannah, Ga but, not that hot.
Thanks in advance.
Old May 13, 2014 | 02:01 PM
rmurer's Avatar
Thanks in advance.
Are you talking about the external temp that reads out on the dash/radio?
If so mine does that randomly. I've chaulked it up to its possibly broken or haunted.
Mine read a 109 degrees when i turned the car on this morning. and i live in Michigan.
Old May 13, 2014 | 02:55 PM
Scott's Avatar
I think that they may pick up some heat radiated off the ground/asphalt. I have gotten a few weird readings, but always has gone back to normal pretty quick.
Old May 13, 2014 | 03:23 PM
Ltngdrvr's Avatar
The sensor is mounted behind the lower grille and is picking up heat from the radiator.
Old May 13, 2014 | 05:24 PM
bjbsav's Avatar
That is what I was thinking. It is the internal radio reading.
Old May 13, 2014 | 07:06 PM
southcarolina12's Avatar
you could check to be sure that the sensor hasnt fallen back near the radiator. mine reads right. located on the driver side of the lower grille.
Old May 14, 2014 | 03:37 AM
bjbsav's Avatar
I will look at that. The very first week that I owned it someone backed into me and the front end had to be repaired. I wonder if they put it back in the wrong spot or have it facing the wrong direction?
Old May 14, 2014 | 03:51 AM
bob's Avatar
bob
Does the exhaust from the vehicle in front of you effect the sensor as well?
I've noticed in traffic that a vehicle in front of me with rearward facing exhaust can heat the air that is being pulled by the radiator and heat exchanger on my car.
Its not a lot mind you, but I've noticed a two degree difference between me being first at the tree compared to me being on somebody's six in traffic.
Old May 14, 2014 | 03:53 AM
bjbsav's Avatar
Yes the traffic definitely does, even sitting a light without traffic. I have seen readings as high as 120F
Old May 14, 2014 | 05:15 AM
Beargap's Avatar
I found mine just dangling after a front bumper repair, and it was reading very high on a sunny day. remounting it in the correct spot returned accuracy. It needs to be in the forward airstream and shielded from the pavement to give a good reading.
Old May 14, 2014 | 05:19 AM
bjbsav's Avatar
I will have to look at it when I get home. :-)
Old May 14, 2014 | 05:20 AM
bjbsav's Avatar
I am guessing that you have to get to it from below?
Old May 14, 2014 | 01:01 PM
i can see mine just looking through the bottom grille.
Old May 17, 2014 | 04:57 AM
bjbsav's Avatar
Well I found it yesterday. I had it up on a lift (getting new wheels/tires) and I asked if I could pull the cover off the front. What I found was the sensor was stuffed into the housing for the radiator. There wasn't any damage done. What troubles me is when I brought into Ford they said they could not find the problem. Which means they didn't even look being that it was so obvious.
Old May 17, 2014 | 10:12 PM
some dealerships are slack like that. im glad you found the problem though. were you able to just put it right back on?
Old May 18, 2014 | 05:32 AM
bjbsav's Avatar
Yes, where in Carolina are a you?
Old May 18, 2014 | 11:08 AM
im in the florence area. its a ways from georgia haha.
Old May 19, 2014 | 01:22 PM
bjbsav's Avatar
Well moving it from being jammed under the radiator and to the correct position has fixed the issue.
May 3, 2026 05:42 AM
Cobiecane
Oct 23, 2015 08:44 AM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
