Suspension Upgrades for a 2012 on order?
Old Feb 27, 2011 | 11:29 PM
ragz06's Avatar
Hey guys,
Just getting back into the nice car scene--prev rides included 98 Cobra, 01 Steeda GT, and 03 Z06 Vette.
Got a '12 Gt on order (arrival ???????)
My main goal honestly regarding the suspension is just to the car lowered. I've read and heard all kind of things--"cant do just springs, wheel hop bad, gonna ride bad, etc..."
I've basically concluded that I cant just do lowering springs. I dont mind spending a little $$--want the car to look good and handle well on the street. Not gonna be at the auto-x or drag strip.
I've been looking at the Ford Racing Handling Pak, which is springs, struts/shocks, upgraded strut mounts, jounce stops, and front/rear sway bars. Has anybody done this upgrade? Thoughts?
What about an adjustable Panhard bar, which I've read will be needed to re-center the rear? Lower/Upper Control Arms??
I was thinking about just going with the K-springs (1.5" drop vs the 1'" P-springs in the package), Struts/shocks, strut mount upgrade, jounce stops, UCA/LCA, and adjust. panhard bar. ???
Any advice much appreciated as I wait on the build of the new 5.0; really enjoying the info from this site!!
Old Feb 28, 2011 | 12:00 AM
blkside's Avatar
I am in the same boat as a bunch of people here as I wont be getting mine until the end of the year in prep for my April 2012 stateside return. So I have been doing some research and found this to meet most, if not all of my needs. Seems to be a very good,well thought out package.
It shows the 2011 so I dont see an issue obviously for the 2012. It is a 1.25" front drop and a 1.5" drop in the rear...
Package includes: $1619.00
Front Swaybar(SB022), Rear Swaybar(SB023), Tokico D-SPEC Adjustable Front struts and shocks(DSP12), Upper Strut Mounts(SM002), Lowering Springs(SP011, SP012), "On-Car" Adjustable Panhard Rod(PHR006), Control Arm Relocation Brackets(CAB005), and Camber bolts(FC001).
Old Feb 28, 2011 | 04:57 AM
erickburke's Avatar
This is the package that came on My Stage 2 Roush:http://store.roushperformance.com/detail.aspx?ID=1549
I couldn't be happier with the overall balance of handling and ride quality.
Old Feb 28, 2011 | 05:19 AM
blkside's Avatar
And for those that care, there are a number of manufacturers than have coilover kits available for 2011/2012. KW,Eibach,Tein as well as a few others..
Old Feb 28, 2011 | 09:40 AM
2012 Black 5.0's Avatar
Sorry if this is posted somewhere else, but why can't we just throw on some lowering springs and be done with it?
Old Apr 11, 2011 | 10:39 PM
ragz06's Avatar
Ok, my dealer is not being too cooperative as I await delivery later this month--build date is 4-11 yeah!
Accessories manager is saying "Ford hasn't told us that the '11 parts will fit the new '12's, warranty, yadda yadda".
I've been trying to tell him that there is no difference between the 11's and the 12's in regards to suspension, I don't give a **** about the warranty, etc...I mean if the 1% chance that the '11 suspension parts won't work, its not like it will void the warranty on the whole car! It is gonna be my car, my money, I cannot believe that I am willing to spend 35 grand on a new car and am asking the dealership to take my money to perform a few simple upgrades and am getting this much resistance!
Any advices from the fellow stangers??
Old Apr 11, 2011 | 10:57 PM
SynisterGT's Avatar
Go find a shop besides the dealer to do it. That what some people do. You could install it yourself but that might not be an option.
Old Apr 12, 2011 | 08:48 AM
Modshack's Avatar
Lots of guys do, but.........>>
Typically the OEM shocks are valved to handle the OEM rate springs (though not very well in reality). Putting lowering springs on the car typically raises the spring rates to the point that the stock shocks cannot handle the suspension movement as well. Damping is inadequate and usually results in some harshness. A better (stiffer) shock will more accurately control the stiffer springs and actually result in a better ride. I've had my car set up both ways, and if you want ride quality AND good handling with your drop, add some shocks when you do the job.
Old Apr 12, 2011 | 09:00 AM
Overboost's Avatar
Couldn't agree more.
One other thing to consider if doing a spring install is the Panhard bar. Your axle may be off-center without installing an adjustable PHB.
Old Apr 12, 2011 | 10:59 AM
jwmurray's Avatar
Noob question: Would it be worth getting a kit like one of these, and then adding a Watts linkage?
Old Apr 12, 2011 | 11:11 AM
Modshack's Avatar
If you're adding a Watts link, you toss the panhard bar. No need to buy both.
M3hunter
Sep 10, 2015 09:26 AM
Steve@CJPP
Sep 3, 2015 10:43 AM
Sep 2, 2015 07:33 PM
