Steering way too light - how do I firm it up?
Old Jul 12, 2012 | 09:58 PM
stillkickin's Avatar
Question Steering way too light - how do I firm it up?
The steering feel lightened up a lot after I swapped my winters for my summer tires (original P Zeros). Steering wheel was also off-center.
Alignment shop centered the wheel but now the feel went from very firm to pretty light, no matter what steering mode is selected. So I use Sport all the time but it still isn't as firm as the old Standard mode. Have about 12-13K on the P Zeros. Alignment already checked OK.
Dealer says its fine. Alignment shop said it could just be the tires wearing down.
Is it the tires? Something else I should be checking?
Car is my DD.
Old Jul 12, 2012 | 10:48 PM
Ltngdrvr's Avatar
Maybe pull the negative battery cable for 10 minutes and reset the pcm, might help.
Old Jul 13, 2012 | 05:06 AM
Ronin38's Avatar
Are your tire pressures too high?
Old Jul 13, 2012 | 10:45 AM
Thanks - didn't think of this...
Will pulling the cable reset the pcm automatically? Or is there an additional step after that?
Old Jul 13, 2012 | 10:52 AM
Should be 35 psi, right? (OEM 19 PZeros)
Thanks!
Old Jul 13, 2012 | 11:45 AM
Ltngdrvr's Avatar
Nope, just pull the cable for 10 minutes and put it back.
You will lose your radio presets though.
Old Jul 13, 2012 | 11:50 AM
Great, will reset the PCM and see what happens. Tire pressure is 35 so it's not that.
Thanks again!
Old Jul 13, 2012 | 11:54 AM
Ronin38's Avatar
Thanks!
I don't know about the 19's, but my 18's are recommended to be 32psi.
Try it, it's free.
I always test the air pressures when I get new tires, to find out what pressure performs and feels the best. Sometimes a couple psi. one way or the other can make a noticeable difference. I had a set of 20's on my last car that ran great at 40 psi.
Old Jul 13, 2012 | 12:30 PM
AzPete's Avatar
I run the 19's on my '11 GT/CS at 29 psi. Tried it all over and found the best all around psi for my driving vs tire wear and pattern.
ricky1728
Feb 11, 2016 07:25 PM
mmb0329
Oct 1, 2015 10:59 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
