Steeda Replacement Shifter Linkage Bushings - 05-10
Old Aug 3, 2012 | 10:36 AM
SteedaBrandon's Avatar
Former Vendor
Arrow Steeda Replacement Shifter Linkage Bushings - 05-10
Mustang Replacement Shifter Linkage Bushings - 05-10 - $29.95
Please let me know if I can help you with this.
These bushings go bad on the stock shifters and Ford won’t sell you these bushings without buying an entire shifter! Our's are also more durable than the stock ones.
Steeda's replacement shifter bushings are designed to reduce slop that develops over time with your aftermarket or factory shifter caused by the shifter linkage bushings wearing out.
The OE replacement bushings are not available from your Ford dealer separately, they can only be obtained by purchasing an entire shifter assembly. Our bushing are more durable, direct replacement upgrades.
Manufactured from high-strength plastic to provide a more direct link to the transmission. Does not require removal of the entire shifter assembly for installation.
Product Benefits
  • High strength plastic reduces shifter slop
  • Prevents purchasing the entire OE shifter just to replace the worn out bushings
  • Does not require any permanent modifications to car
Jul 8, 2016 08:53 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
Sep 2, 2015 07:33 PM
