Snapping/popping noise from front of car when stopping 2011 - GT - Auto
Old Jun 8, 2019 | 03:29 PM
Ron11's Avatar
One or both of your control arm bushings are bad.
Old Jun 9, 2019 | 04:54 AM
Ginger Pony's Avatar
Bushings
Thanks for the reply Ron11,
How did you determine your bushings were bad? I looked at mine prior to cleaning the crud from the brake pads, but didn't see any obvious signs of wear or damage. Can the bushings be installed without dropping the whole LCA assembly?
Not having to hear that popping - cracking sound is a big relief, and hard to believe the brake pads attributed to it. So maybe the bushings could be worn out because the car made a loud slamming sound when I drove over a raised concrete lip between coming off a paved road. Front shocks are new, and the car has almost 89K on it.
The road crews in this state can't figure out how to make roads flat. They dump asphalt in a hole, leaving the mound for cars to flatten out. Cars take a beating in this state. I'm always maneuvering around pot holes, moguls, and sunken surfaces. Tax dollars at work...........
Thanks.
Old Jul 10, 2019 | 01:13 AM
dripper's Avatar
if it doesn't go away...i would take in for service...just to be on safe side.
or pull wheels and take a look yourself (if you know what your doing)
Old Nov 1, 2020 | 06:58 PM
Mark Angel's Avatar
L enter and out of tie rods
Originally Posted by Argetni
Yeah it stops fine. It does sound like a pad snapping into place kind of.
I tried two hard stops from 40 but no change.
I just moved the car in the parking lot at work and could not get it to make the sound so it seems like it has to be driven for a bit first to do it.
Maybe I will try some hard stops from 60 or 80 as a "test".
Sounds sounds like tie rods to meafter you've driven on them for a while they will begin to pop or snap at low speeds because the joints are wore out.
RRRoamer
Jan 19, 2017 05:27 PM
jc46002003
Apr 15, 2016 03:00 PM
Mustang259
'10-14 Interior and Audio
74
Mar 25, 2016 04:27 PM
ssjbuu
Aug 28, 2015 08:55 AM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
