Rear License Plate Problem HELP!!!
Old Mar 30, 2013 | 10:32 PM
RangerDLA's Avatar
Hey Guys,
I just bought my '13 Boss 302 and the rear (left side) license plate hole is stripped. Any ideas what I can do? I'm slightly OCD, so my license plate not hanging securely and evenly is killing me. Please help! Thanks
Old Mar 30, 2013 | 10:46 PM
Sieran's Avatar
Originally Posted by RangerDLA
Hey Guys,
Could buy a slightly larger screw, or JB weld the hole up and "retap" it (just be careful).
Old Mar 30, 2013 | 10:49 PM
11SHELBYGT500's Avatar
How did you even do that if you're using the proper screws?
Old Mar 31, 2013 | 09:13 AM
2014grabber's Avatar
You could also just remove the interior panel, and then install a matched pair of screws with nuts on the inside. Yes, it would be just a bit of work, but you likely don't need to be removing the tag for a very long time, anyhow. That also opens up a whole lot of options for the style of bolt head. Personally, I often use the 1/4" diameter stainless allen head bolts from Home Depot. Sand the heads smooth with some fine sandpaper, then polish them and they will shine almost like chrome.
Old Mar 31, 2013 | 06:40 PM
Paulyray's Avatar
If it was me, I would squirt a blob of gel superglue into the stripped hole, let it dry, then reattach the plate.
Old Mar 31, 2013 | 07:54 PM
14Glassback's Avatar
I do not have my car yet so I cannot answer the question easily. Is the threaded hole a plastic insert or is it drilled into metal? If plastic most of the time you can replace the plastic nut. If it is metal it is more difficult. We see a lot of plate screws corrode into metal trunk lids at the dealer I work for. You pretty much get one shot to fix it if this is the case. I would take it to a dealer or quality mechanic with proper taps and thread chasers. Otherwise if you try to fix it yourself you run the risk of permanently ruining it. Would rather pay a expert to fix it right than shade tree it myself. Just my opinion...
Old Mar 31, 2013 | 08:14 PM
RangerDLA's Avatar
It's plastic and I'll give that a shot. Thanks.
houtex
05-09 Exterior Modifications
13
Apr 17, 2025 10:53 PM
robjh22
Custom Vanity Personalized License Plates & Brackets /Delete Brackets
14
Nov 1, 2015 11:28 PM
lowblustang00
Sep 5, 2015 12:18 PM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
