quick wax question on black
Old Jul 16, 2010 | 04:30 PM
Huskernation's Avatar
I put a coat of the nxt tech wax 2.0 on my black gt and was not real happy. it seamed to streak some but I may not have let it dry enough. Anyway, I ordered some of the adams buttery wax and was wondering if I need to remove the tech wax before applying the buttery wax and if so what should I use to do that.
Old Jul 16, 2010 | 04:35 PM
wolfy63's Avatar
Megs NXT is great wax...you need to let it cure....sounds like you tried to take it off to fast.
Old Jul 16, 2010 | 04:42 PM
Jott's Avatar
I was reading that it's a good idea to let the factory paint "cure" before applying wax, and that I should hold off for awhile (car built in June). Any truth to this?
Sorry semi off-topic but not worthy of its own thread.
Old Jul 16, 2010 | 04:44 PM
I was not saying it was a bad wax just that I was not happy with it and the adams gets great reviews and it sounds like it's very easy to use. I am just wondering if I need to remove the nxt first or if I can just go over it with the adams.
Old Jul 16, 2010 | 04:45 PM
wolfy63's Avatar
BS....clay it when you get it..then follow with a nice polish...then 2 coats of your fav wax...nuff said
Old Jul 16, 2010 | 04:51 PM
i did clay it but did not polish yet
Old Jul 16, 2010 | 05:29 PM
wolfy63's Avatar
Like i said megs nxt has to cure...maybe you wiped it to early and introduced streaking to the paint...if you clayed thats a good start.....you should go to autogeek.net and read up on how to do a proper job....Not trying to be hard on you but your paint will be happy and so will you...try to learn by reading the forums over there
Old Jul 16, 2010 | 05:55 PM
got the adams already ordered so I am going to at least give it a try. I probably did remove the nxt too soon. I don't plan to polish right away but maybe in a few months. So back to the question. Is it ok to just go over the nxt with the adams if not how should I remove it? I know people say dawn will work to remove but is it a good thing to use?
Old Jul 16, 2010 | 11:14 PM
tom_vilsack's Avatar
im guessing no help for you new car guys...but my 93 was faded big time when i first got (just over a month ago)...i used meguires cleaner wax...and em i ever pleased with results (did it 3 times)...
pics in user album section (wish i had taken before shot...to show the BIG diff)
ps: another old fox i used to own,and my 91 taurus i used nu-finish...and both turned out great!
Old Jul 17, 2010 | 12:32 AM
Really not a fan of nxt 2.0, I liked the original better.
It didn't work well on my black car either. I've since moved on to some others.
Old Jul 17, 2010 | 06:15 AM
Silverback's Avatar
Needs to cure/dry before removal and then it's great wax. Be patient Grasshopper.
If you want to change waxes: Clay bar the car after a wash and go for it.
Old Jul 17, 2010 | 06:26 AM
karman's Avatar
Post
Not True.
Factory paint is cured already.
Stop reading so much BS.
Paint shop paint usually needs time to cure.
Old Jul 17, 2010 | 09:54 AM
86LXJunker's Avatar
Ive been using NXT 2.0 and found that it works best if you let it dry for a while before trying to remove it. Also - make sure your car is really cool - I try to do my cars in the garage now - first thing in the moring before the sun even comes up.
Works Great.
Old Jul 18, 2010 | 06:43 AM
Double-EDad's Avatar
For a black or Kona blue or other dark color car, I'd use only Zaino #5 (zainobros.com).
Jim74656
May 1, 2023 02:15 AM
ssjbuu
Aug 28, 2015 08:55 AM
Feffman
Aug 22, 2015 06:27 AM
Feffman
Midwest
Aug 15, 2015 08:08 AM
John H
Jul 30, 2015 08:33 AM
